Dakota R/T trans? #1810115
04/23/15 01:25 PM
04/23/15 01:25 PM
O'Fallon,IL.
70RTRacer Offline OP
O'Fallon,IL.
My son has a 2001 Dakota R/T that he has started racing in the High School class. The trans is acting funny (you have to let off the gas to get it to shift)so I found a 2000 R/T trans that is rebuilt. Will a 2000 work in a 2001 computer wise? Just do not want to buy one that will not work.
Thanks,
Brian
Re: Dakota R/T trans? [Re: 70RTRacer] #1810187
04/23/15 02:55 PM
04/23/15 02:55 PM
GEORGIA
barracuda7199 Offline
GEORGIA
before i would go thru the trouble of doing a tranny swap, i would check the governor sensor and make sure it is plugged in and if the sensor is cheap swap it out and see if that fixes it. its in the front of the overdrive section kind of at an angle.should be fairly easy to spot.
Re: Dakota R/T trans? [Re: barracuda7199] #1810198
04/23/15 03:09 PM
04/23/15 03:09 PM
O'Fallon,IL.
O'Fallon,IL.
Ok. I will take alook.
Re: Dakota R/T trans? [Re: 70RTRacer] #1810306
04/23/15 06:01 PM
04/23/15 06:01 PM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
if the bands aren't worn out (you can tell this by the adjustment if you have to turn in the bolt all the way then they are worn out)and isn't slipping then 99% of the time the governor solenoid is bad/going bad. Go on ebay and search for the borg warner gov. solenoid as it is a larger solenoid and will handle higher presures better and last longer. What happens is the solenoid exhausts itself on when first start to reset the posistion at the same spot everytime. well they get weak or stick from debris, the stock solenoid is weak and and can't operate at the lower speeds which use lower voltage levels to move the solenoid to shift the gears. I would get a borg warner govenor solenoid and mopar governor pressure sensor and replace both of them at the same time. They are easy to replace as they are held by a bracket on the side of the valve body.
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: Dakota R/T trans? [Re: slammedR/T] #1810330
04/23/15 06:36 PM
04/23/15 06:36 PM
O'Fallon,IL.
O'Fallon,IL.
It does not seem to be slipping. Also, it is fine when cold and starts doing it when it warms up. So, are both the sensor and the solenoid on the valve body?
Re: Dakota R/T trans? [Re: 70RTRacer] #1810389
04/23/15 08:02 PM
04/23/15 08:02 PM
slammedR/T Offline
slammedR/T  Offline
Yes the sensor is up on the side while the solenoid is pointing down you can't miss them and are very easy to change once you drop the pan. Might aswell change the filter and adjust bands while replacing the sensors.
racemagnum
Re: Dakota R/T trans? [Re: 70RTRacer] #1810391
04/23/15 08:04 PM
04/23/15 08:04 PM
slammedR/T Offline
slammedR/T  Offline
Borg warner solenoid (bigger one on left) next to stock mopar solenoid(smaller one on right)
racemagnum
Re: Dakota R/T trans? [Re: slammedR/T] #1810403
04/23/15 08:12 PM
04/23/15 08:12 PM
O'Fallon,IL.
O'Fallon,IL.
OK. Thanks! Any tips to get it down the track faster? It has air filter, exhaust, and drag radials. Best run is a 14.96.
Re: Dakota R/T trans? [Re: slammedR/T] #1810416
04/23/15 08:28 PM
04/23/15 08:28 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Well thank you too! up
Jut about to change my trans oil and filter.
How do you adjust the bands. popcorn
Matt
Re: Dakota R/T trans? [Re: 70RTRacer] #1810487
04/23/15 09:49 PM
04/23/15 09:49 PM
slammedR/T Offline
slammedR/T  Offline
Yeah, nitrous! LOL!
racemagnum
Re: Dakota R/T trans? [Re: MattW] #1810488
04/23/15 09:50 PM
04/23/15 09:50 PM
slammedR/T Offline
slammedR/T  Offline
Matt
If stock ratio lever on kick down band, tighten to 72inch lbs. and back off 2 1/2 turbs for the kick down band(on driver side of case above front oil cooler line fitting. Low/reverse band have to have the oil pan dropped and adjust it to 72inchlbs. and then back off two turns.
racemagnum
Re: Dakota R/T trans? [Re: 70RTRacer] #1810495
04/23/15 09:57 PM
04/23/15 09:57 PM
slammedR/T Offline
slammedR/T  Offline
Low/reverse band adjustment;
Front or Kickdown band adjustment;
racemagnum
Re: Dakota R/T trans? [Re: 70RTRacer] #1810821
04/24/15 11:36 AM
04/24/15 11:36 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
1-2 shift, or 2-3 shift? Kind of important to know...... 1-2 I'd be leaning toward a neglected kick down band. 2-3 front clutch piston retainer seals.
Re: Dakota R/T trans? [Re: slammedR/T] #1810907
04/24/15 01:28 PM
04/24/15 01:28 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Thank you once again up
Forgot to mention I have a 2003 dakota 2wd with a 4.7.
Are the parts Numbers and the adjustements the same?
22958 for the soleniod?
I believe my trans is the 45fre.
Thx Matt
Re: Dakota R/T trans? [Re: 70RTRacer] #1811013
04/24/15 04:05 PM
04/24/15 04:05 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
The ONLY thing in common with a RE trans and RFE trans is the +4 fluid.
Re: Dakota R/T trans? [Re: MattW] #1811070
04/24/15 06:30 PM
04/24/15 06:30 PM
slammedR/T Offline
slammedR/T  Offline
Thx Matt
NO! the 45rfe behind that 4.7 is completely different from the 46re I posted. They do not have band adjustments, just replace the filter and fill with transmission fluid.
racemagnum
Re: Dakota R/T trans? [Re: J_BODY] #1811073
04/24/15 06:36 PM
04/24/15 06:36 PM
slammedR/T Offline
slammedR/T  Offline
Fixed many a 1-2 shift issue when it involves having to let off the throttle to get it to shift with the governor solenoid.
front clutch piston retainer seals?? I know the piston retainer not having enough return springs can cause a shift flare on the 2-3 shift.
racemagnum
Re: Dakota R/T trans? [Re: 70RTRacer] #1812161
04/26/15 09:44 AM
04/26/15 09:44 AM
Sweden
Tobbe Offline
Tobbe  Offline
Sweden
it there is a shiftkit in the trans the bumped linepressure could mess upp the pressure reading for the ecu .there is a mod to put a resistor in the wiringharness fooling the ecu to think there is oem pressure
there is a simple box for the dieseltrucks that could be used (it have a adjustible resistor) but i dont remebere the brand right now.
Re: Dakota R/T trans? [Re: slammedR/T] #1812190
04/26/15 10:53 AM
04/26/15 10:53 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Thx again.
Bought my filter a long time ago. Now i'm thinking I have the wrong one. Will have to find it to find out.
Once gain thanks for the info.
P.S. Did a quick google search an it seems that putting a shift kit inside a RFE is very simple. I'll look into the TRANS GO kit.
Matt
Re: Dakota R/T trans? [Re: Tobbe] #1812551
04/26/15 09:22 PM
04/26/15 09:22 PM
slammedR/T Offline
slammedR/T  Offline
the shift kits for the 46re will typically come with this resistor, I'm conservitive on the line pressure with them if they don't have the extra upgrades needed like borg warner governor solenoid, teflon seal rings and the extra springs in the front clutch. The stock solenoid can't handle the etra line pressure and will eventualy start stick and causing 1-2 shift issues and the 2-3 shift will typically flare without the added clutch retainer springs.
racemagnum
