Head Gaskets for 13.5-1 #1808653
04/21/15 03:09 PM
04/21/15 03:09 PM
Kentucky
clovis Offline OP
clovis  Offline OP
Kentucky
I have looked through several threads for head gaskets and there is some great information however the one piece that seems to be missing is recommended compression ratio. What are my options if I have a 4.380 bore and want a .040ish or less compressed height? I do not want a wire ring as I am running aluminum heads and I have had to cut once already to remove the marks left by a 1009. Will the Edelbrock 7325 or the Mopar P4349559 handle 13.5-1? I would rather stay out of the $200 club for Cometic. The Mopar P4349559 has claims a 4.380 bore so I didn't know if would actually fit a 4.380 cylinder.
I have been running the 8519 and they have held for a year but on teardown I can see a little cylinder to cylinder crossover.
'75 Plymouth Duster
Phase I 451 906/590/2-660 10.75/126
Phase II 451 Stage VI/590/1050 9.82/135
Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
Re: Head Gaskets for 13.5-1 [Re: clovis] #1809297
04/22/15 11:22 AM
04/22/15 11:22 AM
NC
440Jim Offline
440Jim  Offline
NC
You said you don't want to spend for the Cometics.
But that is what I have used at that CR for around 10 years and love them. I even reuse them a few times when disassembling for inspections or freshen ups. Reusing cuts the cost.
Re: Head Gaskets for 13.5-1 [Re: 440Jim] #1809305
04/22/15 11:29 AM
04/22/15 11:29 AM
an8sec70cuda Offline
iagree
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Head Gaskets for 13.5-1 [Re: clovis] #1809325
04/22/15 12:16 PM
04/22/15 12:16 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Cometics aren't that expensive if you buy them at the right place.
http://www.4secondsflat.com/Cometic-MLS_Gaskets.html
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Head Gaskets for 13.5-1 [Re: clovis] #1809328
04/22/15 12:20 PM
04/22/15 12:20 PM
Lakewood, Colorado
runnerrt Offline
runnerrt  Offline
Lakewood, Colorado
The Mopar P4349559 are what I ran with my aluminum 452 because that's what Mopar recommended. When they showed up, low and behold they were Fel Pro 1009's
1969 Super Bee High School car I got back 2004 Ram 2500
Re: Head Gaskets for 13.5-1 [Re: pittsburghracer] #1809693
04/22/15 08:56 PM
04/22/15 08:56 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
I agree on the Cometics
