Re: Indy 360-1?
[Re: justinp61]
#1805399
04/17/15 01:38 AM
04/17/15 01:38 AM
Posts: 2,644 North Carolina
sasquatch
North Carolina
Larry has been porting my stuff for over a decade. He does all my stuff. His ability to match port volumes and blance between ports is uncanny. You will not be disappointed. Todd
Re: Indy 360-1?
[Re: justinp61]
#1808251
04/21/15 12:31 AM
04/21/15 12:31 AM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
After talking to a bunch head guys and engine builders I shipped my heads and intake to Larry Smith today. He wasn't at the shop when I called so Hollis gave me his cell number. I called and left a message explaining what I was looking for and within 10 minutes he called back. Super nice guy, he was on the phone with me for probably 15 minutes and answered all my questions. Hollis also gave me Mark (MRL Lifters) number and I spent about 20 minutes on the phone with him. Another very nice knowledgeable guy who doesn't care to answer questions. Hollis, you are A-1 in my book . Thanks for hooking me up. I also have to say thanks to Brett Miller for telling me straight up he was to busy to do the work I needed done and answering a ton of questions. I'm still afraid of that 4.25" crank deal though.
Re: Indy 360-1?
[Re: Streetwize]
#1808722
04/21/15 04:42 PM
04/21/15 04:42 PM
justinp61
W. Kentucky
Justin,
I think you're gonna be REAL HAPPY with the people you're dealing with I think you're right Bobby. Hollis answered bunch of questions and explained some of stuff to me also. I felt bad taking up so much of his time and not buying anything from him. I will go through him for my lifters and will see about pistons. I talked to Rod about a crank today, thinking about a 4.125" instead of a 4.250". This should be a fun little engine.
Re: Indy 360-1?
[Re: justinp61]
#1808751
04/21/15 05:30 PM
04/21/15 05:30 PM
Posts: 9,876 Weddington, N.C.
Streetwize
Weddington, N.C.
Stock block I'd go 4.125/6.200, Race Block I'd go 4.25"/6.25" 0r 6.300" with a SRP NASCAR Style slipper skirt piston and a .912" pin, still gives you a decent 1.15" CH
I remember Ron Silva built that 501" SB beast with a 4.500" (rifle drilled mains) crank
Always wanted to do a Resto Block with at least a 4.185" bore size and throw that 4.25" crank at it.
I threw the 4.25" in that W2 440"/360 just cause I'm never gonna rev it past maybe 6000-6200
Re: Indy 360-1?
[Re: justinp61]
#1808757
04/21/15 05:37 PM
04/21/15 05:37 PM
BradH
... Mark (MRL Lifters) number and I spent about 20 minutes on the phone with him. Another very nice knowledgeable guy who doesn't care to answer questions. Doesn't CARE to answer questions, or doesn't MIND answering questions? I believe you meant the latter. Must be a regional thing, "doesn't care to help" or "doesn't mind helping" are the same thing around my part of the country. Very good guy regardless of the verbiage. Do y'all pronounce the name "Mike" like "Mark" there, too?
Re: Indy 360-1?
[Re: Streetwize]
#1808785
04/21/15 06:10 PM
04/21/15 06:10 PM
Posts: 733 jacksonville,FLORIDA
slammedR/T
I threw the 4.25" in that W2 440"/360 just cause I'm never gonna rev it past maybe 6000-6200 Stock small block mopar will fit the 4.125" stroke crank with 6.200" rods?? what about piston crown with that combo?? is it like the "426" stroker kit where the piston crown is thin and can't run more than 150 shot or boost on the combo?
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
Re: Indy 360-1?
[Re: slammedR/T]
#1808789
04/21/15 06:14 PM
04/21/15 06:14 PM
Streetwize
Weddington, N.C.
my 440" W2 has 6.200 Rods and a $.25" stroke.
Hollis and I went with a SBC piston to get the CR like we wanted and wound up having to give it a new set of Eyebrows.
Re: Indy 360-1?
[Re: DavidDean]
#1808918
04/21/15 08:56 PM
04/21/15 08:56 PM
Posts: 1,534 bronx n.y
one bad fish
bronx n.y
If Bret is too busy try Brian at IMMengines.com. He did a set of 360-1 for me and they were EXCELLENT ! Great work ,great guy always very helpful. My X block, 360-1 headed 454 SB has been 5.66 @ 120. 4.125 bore 4.250 stroke from BPE also another great guy! . How much did the car weigh
Re: Indy 360-1?
[Re: one bad fish]
#1809336
04/22/15 12:28 PM
04/22/15 12:28 PM
Posts: 1,632 Lubbock,TX
DavidDean
Lubbock,TX
If Bret is too busy try Brian at IMMengines.com. He did a set of 360-1 for me and they were EXCELLENT ! Great work ,great guy always very helpful. My X block, 360-1 headed 454 SB has been 5.66 @ 120. 4.125 bore 4.250 stroke from BPE also another great guy! . How much did the car weigh 2875 LBS
Re: Indy 360-1?
[Re: BradH]
#1809579
04/22/15 05:10 PM
04/22/15 05:10 PM
justinp61
W. Kentucky
... Mark (MRL Lifters) number and I spent about 20 minutes on the phone with him. Another very nice knowledgeable guy who doesn't care to answer questions. Doesn't CARE to answer questions, or doesn't MIND answering questions? I believe you meant the latter. Must be a regional thing, "doesn't care to help" or "doesn't mind helping" are the same thing around my part of the country. Very good guy regardless of the verbiage. Do y'all pronounce the name "Mike" like "Mark" there, too? Naw, we say it like ya'll do. What's bad is I didn't talk to Mark or Mike . I talked to Brad at BAM . My youth is catching up with me .
