replacing Federal PS Pump
#1805561
04/17/15 01:07 PM
04/17/15 01:07 PM
Posts: 445 Fairfield, Ohio
holtzdog55
Fairfield, Ohio
Is it hard to replace this pump? can I just loosen bolts and hoses to get it to come off the belt which is really tight?
The fluid has all leaked out over the winter....I have a rebuilt one I bought...... Thanks,
Finally Done....BEERS!!!
Re: replacing Federal PS Pump
[Re: holtzdog55]
#1805987
04/18/15 12:13 AM
04/18/15 12:13 AM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
If you loosen that lower water pump bolt, it should slide over on the bracket and let you get the belt off. Otherwise it's easy but you'll need a pulley puller/installer to get the press fit pulley off and on.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
[Re: holtzdog55]
#1806173
04/18/15 11:28 AM
04/18/15 11:28 AM
holtzdog55
Fairfield, Ohio
Thanks,
Once I get it off I can take it to a shop and get them to take off pulley and put it on the new pump.....
[Re: holtzdog55]
#1806277
04/18/15 02:18 PM
04/18/15 02:18 PM
holtzdog55
Fairfield, Ohio
does this pulley need to be pulled off then pressed on to the new pump?? Looks like it might screw on???? that would save alot of time....lol
