Re: New spoiler [Re: Mr.Yuck] #1808007
04/20/15 07:45 PM
04/20/15 07:45 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Originally Posted By Mr.Yuck
Originally Posted By GoodysGotaCuda
Originally Posted By jcc
Does this have a yet to be installed back window? I would think the airflow would rather turbulent without a window, and decrease efficiency of the spoiler requiring it to be much higher to be useful and therefore greater drag. What speeds are talking?
That will definitely be a point of turbulent air. I would have sealed that up well before worrying about a spoiler. But that's just my 2cents...the spoiler looks like good handy-work though!
we get dinged for Lexan/plastic $X per cubic inches/feet. We are close to the $500 limit now. Once we see how much room we have after our mods are added up. We should have room for the rear hatch.
Hmm, I would try to get something on there.
May be work some Tuft testing to see how bad you want it, it'll at least give you some sort of feedback on what's going on back there.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: New spoiler [Re: Mr.Yuck] #1808017
04/20/15 07:58 PM
04/20/15 07:58 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Wrap a piece of sheet metal around it and fire up the mig.
Rearward vision is highly overrated.
- Stu Harmon
Re: New spoiler [Re: feets] #1808486
04/21/15 11:02 AM
04/21/15 11:02 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
We get hit for sheet metal too. It's funny that you say rearward vision is over rated, my team mate yelled at me on the radio to stop looking in the rear view mirror and worry about what was in front of me.
Re: New spoiler [Re: Mr.Yuck] #1808703
04/21/15 04:17 PM
04/21/15 04:17 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
When you get the size figured out, layup some carbon fiber, it will be way less weight and mucho stiffer. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: New spoiler [Re: Mr.Yuck] #1808800
04/21/15 06:28 PM
04/21/15 06:28 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Are you required to have a windshield?
Some tin work inside the rear window area will help turn it into an extension of the spoiler deck.
Re: New spoiler [Re: astjp2] #1808881
04/21/15 08:29 PM
04/21/15 08:29 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I think that may be a little more expensive than plastic or sheet metal.. bondo
2020 RAM 1500
Re: New spoiler [Re: Mr.Yuck] #1809059
04/21/15 11:18 PM
04/21/15 11:18 PM
NY NY
3
340duster340 Offline
NY NY
you could make it tunable with turn down flaps, or just saw-zall away.
it looks like you have a piano hinge at the bottom, you could use turn buckles on the same side to adjust the height/angle rather than have fixed mounts.
also what kind of speeds are we talking about?
1966 Dart GT ...down to only 1 mopar for the first time in 15 years!
Re: New spoiler [Re: 340duster340] #1809287
04/22/15 11:07 AM
04/22/15 11:07 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
We have to run something up front. Some run Lexan but the stock window is free.
We used a piano hinge so we can adjust it some. However we are somewhat limited. For faster tracks we'll use a shorter piece of plastic.
Carbon fiber...not even sure what they would charge for that. Plywood is $3 sq foot and the Lexan is $5 a sq foot. I talked things over with the team and the car w/ spoiler and splitter is going to be around $465. That gives us some wiggle room for the rear window next race. If need be we can use the stock PS cooler and save $20 more.
Re: New spoiler [Re: Mr.Yuck] #1809341
04/22/15 12:36 PM
04/22/15 12:36 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Fab up a set of rear window louvers. It might help straighten out some of the air flow through the car and onto your spoiler.
Throw the judges for a loop and use papier mache.
- Stu Harmon
Re: New spoiler [Re: feets] #1809643
04/22/15 07:19 PM
04/22/15 07:19 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
funny you should say that. I said I'll get a set of louvers and we should be good. They do not count against the car. The team said they are ugly I said so is the entire car.
Re: New spoiler [Re: Mr.Yuck] #1809738
04/22/15 10:00 PM
04/22/15 10:00 PM
Central Jersey
MagillaGuerrilla Offline
Central Jersey
[/quote]
we get dinged for Lexan/plastic $X per cubic inches/feet. We are close to the $500 limit now. Once we see how much room we have after our mods are added up. We should have room for the rear hatch. [/quote]
If this is for ChumpCar, check the rulebook for 2015 updates - Lexan rear windows (including hatch) are now free so long as they conform to the OE size, shape, and location. See Rule 9.1.6.3 and Rule 9.1.7.1 here
Re: New spoiler [Re: MagillaGuerrilla] #1810006
04/23/15 09:59 AM
04/23/15 09:59 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
Originally Posted By MagillaGuerrilla
[/quote]
If this is for ChumpCar, check the rulebook for 2015 updates - Lexan rear windows (including hatch) are now free so long as they conform to the OE size, shape, and location. See Rule 9.1.6.3 and Rule 9.1.7.1 here [/quote]
good to know, Thanks
