Yeah guys I was just wondering as t what kinda combo it would make for thats all.
With the smaller bore larger stroke, how would "breathing" be affected?
As far as optimum bore v stroke in a Hemi goes, where would this combo sit ?
Out of the box Hemi heads flow 360-370cfm, which is plenty for a 4.25 stroker on a mild motor even bore size limited. Obviously, you can spend a lot more and flow a lot more. But stroke equals torque and is what gets a heavy car moving.
To date, the most popular combo is 4.5 bore with the 4.15 stroke or what they call a 528. They have been known, with good heads and compression to exceed 800hp....But if your goal is killer torque, a bigger stroke is even better. The 4.15 crank is super popular and very reasonably priced these days...
Me, I went 4.75 stroke on a 4.5 bore with the heads right at 457cfm....In a mild, hopefully parts friendly 605 Hemi.....The bigger kits are becoming more affordable, but you want to taylor the whole package so you don't spend money to fix mis-matching parts.
If you have parts already, build what you have, if your buying new, go as big as you can afford...The 572 4.5 x 4.5 is an absolute beast if you want basically the ultimate in Hemi. The 605 will be more by a bunch due to some other choices you need to think about.
