Re: The turbo Cuda build has begun
[Re: go green]
#180183
01/02/09 11:47 PM
01/02/09 11:47 PM
Posts: 248 Jarrettsville, MD
cudaman1967
Jarrettsville, MD
Ha! Quick and Dirty at a final at capitol last year to mess with the chevy guys!
Cudaman1967
1967 Barracuda Turbo Outlaw 8.50
#180184
01/02/09 11:51 PM
01/02/09 11:51 PM
cudaman1967
Jarrettsville, MD
Kevin at CSU is doing a dominator for it. That is my alcohol Dominator on it that I bracket race with for mocking up.
Gasoline on the street with water/meth injection, race gas at track. 15-20psi at the track, 8psi around town. You will start to see more and more dominators as time goes on. They are starting to find they work well even on lower HP motors (1000hp or less)
Cudaman1967
[Re: cudaman1967]
#180188
01/03/09 10:07 AM
01/03/09 10:07 AM
#180189
01/03/09 11:48 AM
01/03/09 11:48 AM
Posts: 4,590 Indy
joshking440
Lunch is on me!
Lunch is on me!
Indy
[Re: cudaman1967]
#180194
01/03/09 10:36 PM
01/03/09 10:36 PM
Posts: 1,771 St.Clair Shores MI.
tilt
St.Clair Shores MI.
How big is that wastegate? Same for the BOV?
68 CORONET R/T BEST MACHINE BUILT EFI'd TWIN TURBO(UP and RUNNING !!)
03 Mach1
[Re: cudaman1967]
#180195
01/03/09 10:49 PM
01/03/09 10:49 PM
Posts: 411 Portersville, Pa
1badx
Portersville, Pa
Both headers built and crossover pipe
Looks good! Good thing you left room for another turbo. My guess is you'll be adding another once you get that setup working.
Here's a video of a rear mounted twin turbo we tuned recently. http://www.youtube.com/watch?v=lQugsN1ucZo I'm hooked. Looking to put twin trunk mounted ht60's on the GTX once I get this 446 up and running. Planning on going blow through on a dominator also. Please keep us posted on your progress.
[Re: go green]
#180199
01/04/09 02:20 PM
01/04/09 02:20 PM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
Your wide band O2 sensor bung is too close to your turbo, you will barbecue it in not time at all.
look how far it is away from the cylinder head.normal distance.
[Re: cudaman1967]
#180201
01/05/09 12:10 PM
01/05/09 12:10 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Turbo is located and passenger header is built. Friday will build the drivers side.
where are you gonna put the radiator???
[Re: Mr.Yuck]
#180202
01/05/09 12:22 PM
01/05/09 12:22 PM
cudaman1967
Jarrettsville, MD
Its in the picture above but I have more photos to post from yesterday that show it a little better.
Cudaman1967
