How many quarts does a 1969 HEMI OIL pan hold?
#1800308
04/10/15 02:42 PM
04/10/15 02:42 PM
Posts: 9,672 Lima, Peru
domingo
EL Master
EL Master
Lima, Peru
Re: How many quarts does a 1969 HEMI OIL pan hold?
[Re: Stanton]
#1800431
04/10/15 05:45 PM
04/10/15 05:45 PM
domingo
EL Master
EL Master
Lima, Peru
6 in the pan and one in the filter So they are the same capacity as the 70-71 hemi pans which also hold 6 quarts...
[Re: Stanton]
#1800523
04/10/15 07:34 PM
04/10/15 07:34 PM
domingo
EL Master
EL Master
Lima, Peru
IM asking because I have an original pan for my 69 HEMI charger....
and I was looking at the HEMI pan repros and it says 70 and 71 repro pans hold 6 quarts. I assume that is 6 + 1 filter= 7
So I was wondering if the 69 pan was the same capacity even though they are a different stamping.
Kinda concerned if the original 69 pan I have will hold too little oil for a high volume oil pump and open clearances on the bearings.....
but I just asked a FAST racer and he told me he uses a stock pan on a WILD stock looking HEMI that gets wound up to 8500 rpm without any problems....so I guess IM safe....
[Re: RoadRunnerJD]
#1800663
04/10/15 10:21 PM
04/10/15 10:21 PM
Posts: 6,232 JERSEY
RJS
JERSEY
[Re: domingo]
#1800810
04/11/15 12:34 AM
04/11/15 12:34 AM
Posts: 9,038 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
but I just asked a FAST racer and he told me he uses a stock pan on a WILD stock looking HEMI that gets wound up to 8500 rpm without any problems....so I guess IM safe.... 1) Does he run a HV pump? 2) I'll bet every bit of the inside of his block is polished to a mirror shine to get the oil back to the pan. Is yours? 3) I ran a 383 out of oil on the top end and put a rod through the block. I was running a '69 Hemi pan and HV pump! I'd suggest trying the standard pump first and switch to the HV if you have pressure issues.
[Re: domingo]
#1801052
04/11/15 02:01 PM
04/11/15 02:01 PM
Posts: 43,744 Bend,OR USA
Cab_Burge
Stock oil capacity for the 1966 to 1969 Street Hemi pans is 5 quarts in the oil pan and one for the regular size oil filter per the FSM. 1970/1971 street hemi/ 440 6 pak is 6 quarts in the pan and one for the oil filter.
[Re: Stanton]
#1801475
04/12/15 02:29 AM
04/12/15 02:29 AM
Cab_Burge
'69 FSM says 6 US quarts in the Hemi pan (5 Imperial quarts). Is that a Dodge or Plymouth FSM?
[Re: domingo]
#1802771
04/13/15 10:36 PM
04/13/15 10:36 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
Basically a deep oil pan is for power by reducing windage. A deep pan holding 6 quarts vs a shallow pan holding 6 quarts. The deep pan will keep the oil away from the crankshaft which equals more power.
