Pictures of b body chargers showing tire/wheel com #1797689
04/07/15 06:24 PM
04/07/15 06:24 PM
Los Angeles CA
xyxxjx Offline OP
xyxxjx  Offline OP
Los Angeles CA
I'm having a hard time deciding on a tire/wheel combo for my 73 charger, I'm looking for pictures of b body chargers showing tire/wheel combos from as many angles as possible. Please state all data of your combo e.g. 295/50/r15 on 10" wheels. Backspacing would also be helpful.
1973 Dodge Charger SE 400 automatic transmission. Curb weight: 3800 lbs. All stock so far. Goal: Reliable everday driveable warmed up 400 as close to 400hp as possible, then a 470 stroker if need be. Don't protect a feminist when the collapse comes!
Re: Pictures of b body chargers showing tire/wheel com [Re: xyxxjx] #1798554
04/08/15 03:32 PM
04/08/15 03:32 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
What size wheels are you interested in using?
- Stu Harmon
Re: Pictures of b body chargers showing tire/wheel com [Re: feets] #1799026
04/09/15 12:38 AM
04/09/15 12:38 AM
Los Angeles CA
xyxxjx Offline OP
xyxxjx  Offline OP
Los Angeles CA
Well, my plan was to go with 15" wheels, but i was told i have many more options in 17-18" range and that 15" might disappear. So I'm looking for pictures of any tire/wheel combo on a b-body to get a feel for different looks, as long as it's stated what's on there.
Re: Pictures of b body chargers showing tire/wheel com [Re: xyxxjx] #1799247
04/09/15 11:04 AM
04/09/15 11:04 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
265/65/16...hum well since they changed the format I have no idea how to add a pix. Anybody else hate the new format? Anyway you have enough room to fix whatever you like. FWIW I wouldn't go over 17" as the larger wheels look dorky on old cars.
Coming soon!!!!
Re: Pictures of b body chargers showing tire/wheel com [Re: xyxxjx] #1799337
04/09/15 12:55 PM
04/09/15 12:55 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Don't have any pics off hand...but 18" will probably give you the widest assortment of tire sizes out there now at least...
Re: Pictures of b body chargers showing tire/wheel com [Re: Mr.Yuck] #1799415
04/09/15 02:35 PM
04/09/15 02:35 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I draw the line at 18" wheels and tires. The biggest thing to keep in mind is the sidewall height. The short tires don't look correct on the older cars.
245/45-18 is BARE MINIMUM for the front of an old car. A 295/50-18 is a good looking tire but selection is a bit thin. That's why I went to the Nitto NT555.
He has a large car with long wheel openings in the rear. It needs a tall tire to fill it out.
- Stu Harmon
Re: Pictures of b body chargers showing tire/wheel com [Re: feets] #1799511
04/09/15 04:47 PM
04/09/15 04:47 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
rear - 275/15
front 255/15
15x8 wheels
lowered stance - Drop spindles front + modded front leaf hanger and 1" lowering blocks rear. NO way this will work without custom offset wheels to fit wheel wells. The owner had to buy 235/15s for the front and move the 255/15 to the rear until buying custom wheels.
Re: Pictures of b body chargers showing tire/wheel com [Re: Mr.Yuck] #1800456
04/10/15 06:33 PM
04/10/15 06:33 PM
Los Angeles CA
xyxxjx Offline OP
xyxxjx  Offline OP
Los Angeles CA
I would agree with that, also higher sidewalls look better on old cars but obviously don't handle as well as lower.
Re: Pictures of b body chargers showing tire/wheel com [Re: Lefty] #1800466
04/10/15 06:47 PM
04/10/15 06:47 PM
Los Angeles CA
xyxxjx Offline OP
xyxxjx  Offline OP
Los Angeles CA
Originally Posted By Lefty
rear - 275/15
front 255/15
15x8 wheels
Nice pictures, I'm leaning towards something like that. Do you know if the 73 charger has the same amount of space in the wheel wells as yours?
Re: Pictures of b body chargers showing tire/wheel com [Re: xyxxjx] #1801089
04/11/15 03:25 PM
04/11/15 03:25 PM
Frederick, MD
71charger Offline
71charger  Offline
Frederick, MD
15x8 with 275/60-15 on rear, 15x7 with 255/60-15 on front
Re: Pictures of b body chargers showing tire/wheel com [Re: 71charger] #1801095
04/11/15 03:39 PM
04/11/15 03:39 PM
Frederick, MD
71charger Offline
71charger  Offline
Frederick, MD
American Racing 200S
Re: Pictures of b body chargers showing tire/wheel com [Re: xyxxjx] #1801405
04/11/15 11:51 PM
04/11/15 11:51 PM
Kentucky
dfsmopars Offline
dfsmopars  Offline
Kentucky
Can't argue with dorky.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
Re: Pictures of b body chargers showing tire/wheel com [Re: 71charger] #1801418
04/12/15 12:20 AM
04/12/15 12:20 AM
Los Angeles CA
xyxxjx Offline OP
xyxxjx  Offline OP
Los Angeles CA
Nice pictures, would you happen to know the backspacing? Also how far does your tires stick out front and rear? Personally I like when they're almost flush with the body.
Re: Pictures of b body chargers showing tire/wheel com [Re: xyxxjx] #1801430
04/12/15 12:54 AM
04/12/15 12:54 AM
Alberta
Wookie316 Offline
Wookie316  Offline
Alberta
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
Re: Pictures of b body chargers showing tire/wheel com [Re: xyxxjx] #1801431
04/12/15 12:55 AM
04/12/15 12:55 AM
Alberta
Wookie316 Offline
Wookie316  Offline
Alberta
Re: Pictures of b body chargers showing tire/wheel com [Re: Wookie316] #1801541
04/12/15 09:40 AM
04/12/15 09:40 AM
moparx Offline
moparx  Offline
wookie, i like the headlite treatment. up tell me more please.
beer
Re: Pictures of b body chargers showing tire/wheel com [Re: 71charger] #1801660
04/12/15 01:29 PM
04/12/15 01:29 PM
Holland MI Ottawa
2
2boltmain Online content
2boltmain  Online Content
Holland MI Ottawa
Every car in this post is great but this car really makes my heart pound like Im 19. Ive always loved the look of (71 Chargers Charger) the TA Radials and classic 15" wheels.
Keep old mopars alive.
Re: Pictures of b body chargers showing tire/wheel com [Re: moparx] #1801924
04/12/15 08:56 PM
04/12/15 08:56 PM
Alberta
Wookie316 Offline
Wookie316  Offline
Alberta
beer
Oracle lighting.
I have the RGB one's that can change to any color.
Re: Pictures of b body chargers showing tire/wheel com [Re: Wookie316] #1802930
04/14/15 12:16 AM
04/14/15 12:16 AM
Wisconsin
beecrazy69 Offline
beecrazy69  Offline
Wisconsin
Wookie316
What size are your wheels and tires?
Re: Pictures of b body chargers showing tire/wheel com [Re: dfsmopars] #1802975
04/14/15 01:16 AM
04/14/15 01:16 AM
Martinsville, VA
440child Offline
440child  Offline
Martinsville, VA
Dfs, what wheela are on your Charger? I like those!
