Pictures of b body chargers showing tire/wheel com
#1797689
04/07/15 06:24 PM
04/07/15 06:24 PM
Posts: 206 Los Angeles CA
xyxxjx
Los Angeles CA
I'm having a hard time deciding on a tire/wheel combo for my 73 charger, I'm looking for pictures of b body chargers showing tire/wheel combos from as many angles as possible. Please state all data of your combo e.g. 295/50/r15 on 10" wheels. Backspacing would also be helpful.
1973 Dodge Charger SE 400 automatic transmission. Curb weight: 3800 lbs. All stock so far.
Goal: Reliable everday driveable warmed up 400 as close to 400hp as possible, then a 470 stroker if need be.
Don't protect a feminist when the collapse comes!
Re: Pictures of b body chargers showing tire/wheel com
[Re: xyxxjx]
#1798554
04/08/15 03:32 PM
04/08/15 03:32 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
What size wheels are you interested in using?
[Re: feets]
#1799026
04/09/15 12:38 AM
04/09/15 12:38 AM
xyxxjx
Los Angeles CA
What size wheels are you interested in using? Well, my plan was to go with 15" wheels, but i was told i have many more options in 17-18" range and that 15" might disappear. So I'm looking for pictures of any tire/wheel combo on a b-body to get a feel for different looks, as long as it's stated what's on there.
[Re: Mr.Yuck]
#1799415
04/09/15 02:35 PM
04/09/15 02:35 PM
feets
Senior Management
Senior Management
Irving, TX
FWIW I wouldn't go over 17" as the larger wheels look dorky on old cars. I draw the line at 18" wheels and tires. The biggest thing to keep in mind is the sidewall height. The short tires don't look correct on the older cars. 245/45-18 is BARE MINIMUM for the front of an old car. A 295/50-18 is a good looking tire but selection is a bit thin. That's why I went to the Nitto NT555. He has a large car with long wheel openings in the rear. It needs a tall tire to fill it out.
[Re: feets]
#1799511
04/09/15 04:47 PM
04/09/15 04:47 PM
Posts: 6,516 Santa Cruz, California
Lefty
rear - 275/15 front 255/15 15x8 wheels lowered stance - Drop spindles front + modded front leaf hanger and 1" lowering blocks rear. NO way this will work without custom offset wheels to fit wheel wells. The owner had to buy 235/15s for the front and move the 255/15 to the rear until buying custom wheels.
[Re: Mr.Yuck]
#1800456
04/10/15 06:33 PM
04/10/15 06:33 PM
xyxxjx
Los Angeles CA
FWIW I wouldn't go over 17" as the larger wheels look dorky on old cars. I would agree with that, also higher sidewalls look better on old cars but obviously don't handle as well as lower.
[Re: Lefty]
#1800466
04/10/15 06:47 PM
04/10/15 06:47 PM
xyxxjx
Los Angeles CA
rear - 275/15 front 255/15 15x8 wheels lowered stance - Drop spindles front + modded front leaf hanger and 1" lowering blocks rear. NO way this will work without custom offset wheels to fit wheel wells. The owner had to buy 235/15s for the front and move the 255/15 to the rear until buying custom wheels. Nice pictures, I'm leaning towards something like that. Do you know if the 73 charger has the same amount of space in the wheel wells as yours?
[Re: 71charger]
#1801418
04/12/15 12:20 AM
04/12/15 12:20 AM
xyxxjx
Los Angeles CA
Nice pictures, would you happen to know the backspacing? Also how far does your tires stick out front and rear? Personally I like when they're almost flush with the body.
[Re: xyxxjx]
#1801431
04/12/15 12:55 AM
04/12/15 12:55 AM
Posts: 326 Alberta
Wookie316
Alberta
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
[Re: 71charger]
#1801660
04/12/15 01:29 PM
04/12/15 01:29 PM
Posts: 4,765 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Every car in this post is great but this car really makes my heart pound like Im 19. Ive always loved the look of (71 Chargers Charger) the TA Radials and classic 15" wheels.
Keep old mopars alive.
[Re: moparx]
#1801924
04/12/15 08:56 PM
04/12/15 08:56 PM
Posts: 326 Alberta
Wookie316
Alberta
wookie, i like the headlite treatment. tell me more please. Oracle lighting. I have the RGB one's that can change to any color.
