Re: Real world weight loss program and it` cost..........
[Re: Thumperdart]
#1900262
08/27/15 10:17 AM
08/27/15 10:17 AM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
What kind of aluminum mufflers are you using? My car slows down about a tenth and 1 mph w/ my "full" 4" H pipe exhaust system on the car, but I bet it's more due to the weight than a restriction issue. I've never weighed it, but it's a lot. Most of the ET loss is early in the run.
[Re: Thumperdart]
#1900305
08/27/15 11:33 AM
08/27/15 11:33 AM
Posts: 836 Up a holler, down a crick
booger
Why not gut the ash tray and rivet it to the dash using the side tabs? It would still look right and weigh just about nothing.
Chasing bears through the woods drunk with a dull hatchet is strongly not advised
[Re: fullmetaljacket]
#1900336
08/27/15 12:11 PM
08/27/15 12:11 PM
Posts: 12,591 Great Neck,LI,new york
hemi-itis
You got it! It will be 1/2 pound when I'm finished with it from a poultry 3 Lbs stock. I only see 1?????????? Ar'nt you supposed to be making 2 of everything??????
#1900381
08/27/15 01:36 PM
08/27/15 01:36 PM
Posts: 1,894 Spahn Ranch
RMCHRGR
Spahn Ranch
Al. My man.
I believe your gloves are different. Ain't that the truth. Bit more hairy than most. Anyway... nice job Lee! Good to see you back at it. Hey what's with the bar that goes across the frame connectors? Never really seen anyone do that before.
'71 Duster '72 Challenger '17 Ram 1500
[Re: RMCHRGR]
#1900419
08/27/15 02:43 PM
08/27/15 02:43 PM
fullmetaljacket
RMCHGR Yeah, Al could use a little lean diet on that Plymouth. I'll fill him in this coming Winter.
That cross bar which is Chromemoly serves as a front Propeller shaft loop as well as a stabilizer between both connectors. As I just noticed, one can not see the hoop loop surrounding the shaft because the photo is dark in that area, but the hoop is welded to that cross bar and the floor to prevent a cock pit breach. I might add a rear hoop as well.
#1900502
08/27/15 04:54 PM
08/27/15 04:54 PM
Thumperdart
State of confusion
Look at what I was following while in Detroit and was ready to high jack it and the Troopers saved him. LOL. So I ASSume the carb`s workin well for ya Lee.........
[Re: hemi-itis]
#1900724
08/27/15 10:59 PM
08/27/15 10:59 PM
Posts: 9,866 MI, usa
dvw
MI, usa
You got it! It will be 1/2 pound when I'm finished with it from a poultry 3 Lbs stock. I only see 1?????????? Ar'nt you supposed to be making 2 of everything?????? No Al, that's incorrect, 3 of everything. Doug
[Re: dvw]
#1900826
08/28/15 01:01 AM
08/28/15 01:01 AM
hemi-itis
You got it! It will be 1/2 pound when I'm finished with it from a poultry 3 Lbs stock. I only see 1?????????? Ar'nt you supposed to be making 2 of everything?????? No Al, that's incorrect, 3 of everything. Doug C'mon Doug,give me a chance to catch up.I've been bit by Jennie Craig.Got a few ounces up my sleeve
