Re: Real world weight loss program and it` cost..........
[Re: booger]
#1354506
12/05/14 07:51 PM
12/05/14 07:51 PM
fullmetaljacket
Is this car we speak of a Roadrunner?
It's nice when dudes will tap on the hood/deck lid expecting fiberglass and hear the sound of metal and not think anything of it that it is gutted on the inside. LOL. Fooled many a curious cat on the streets back when. Sheee, I'd even take it further. I'd have the underside skeletal structure airbrushed back on to simulate panels still intact. A quick glance will not detect it. I've patina aluminum to look like iron back when also. All fun in the eyes.
[Re: Troy]
#1354508
12/05/14 08:18 PM
12/05/14 08:18 PM
fullmetaljacket
I'm sure he'll answer shortly but IIRC when I did my hood which was about 68 Lbs bone stock, it ended up being only 18 Lbs more or less taken off. This was of course way before I went Aluminum on the whole thing which took off a lot more. In general, the undersides do not garner too much to break open the champagne, where as the real weight is in the flat lands panels of either the hood or deck lid. Every ounce counts as they say and its high and up front on the car. The deck lid undersides on the other hand takes off little since its less real estate of skeletal structure. It is fun though and most importantly, Free. I'd do it if I were on a budget.
[Re: Troy]
#1354510
12/06/14 07:59 PM
12/06/14 07:59 PM
Posts: 836 Up a holler, down a crick
booger
Did you weigh the part that you cut out?? Just wondering what that weight was on it.
No idea what it weighed, it was done long before I got the car. It couldn't have saved much, but you know how it is, to lose 100 pounds you have to lose a pound in 100 places.
The dashboard had been trimmed to where it was basically a flat sheet of metal, all non-visible metal was trimmed back. They even gutted the ash tray and riveted what was left back to the dash.
I did not scale the car as it sat when I bought it, but the bar I cut out had to weigh more than the metal they cut out.
Chasing bears through the woods drunk with a dull hatchet is strongly not advised
[Re: booger]
#1354511
12/06/14 08:12 PM
12/06/14 08:12 PM
booger
BTW they also cut out the underside of the cowl, then cut out and welded over the wiper holes and louvers on the top. That always seemed like a waste of effort compared to just deleting the wiper linkage and motor but leaving the cowl as it was.
I'm trying to find a creative way to make that waterproof because it's got to go back in - we've got an annual safety inspection here, and it won't pass without wipers. Get noticed on the street with no sticker, then they'll notice no wipers, and would probably impound my car.
I've got an entire upper and lower cowl to use but if I could get away with not patching the lower cowl panel back in it'd be a lot less work.
FWIW, see image for the evidence of the culprit. I asked Arlen about it once and gave me the answer I expected, they were just old cars and it's what the customer wanted.
[Re: fullmetaljacket]
#1354513
12/06/14 10:11 PM
12/06/14 10:11 PM
booger
I don't know about that, it's really just an old worn out bracket car with a fancy VIN ![](/ubbthreads/images/graemlins/shruggy.gif) I've only noticed one place where the body is tweaked - there's a crack in the roof at corner of the passenger side rear window. It's not a post car so that's no surprise. I guess it was plenty stiff enough even with all the metal cut out of it - with the bar in. The car was modified in about 76 and was raced regularly from then until I ended up with it.
[Re: booger]
#1354515
12/24/14 04:14 AM
12/24/14 04:14 AM
Posts: 9,108 Rogue River, OR
Jeremiah
Rogue River, OR
Is this the car that b body bob had?
#1354517
02/22/15 12:14 AM
02/22/15 12:14 AM
fullmetaljacket
In between my madness and trying to get back on the grinding block to lighten the load, I figured why not show an item that if I were to build a F.A.S.T or just lightweight Maximum Wedge, these aluminum alloy babies would be in charge of exiting the exhaust charges. Exit, stage left.
#1354519
02/23/15 04:10 AM
02/23/15 04:10 AM
Posts: 4,715 Wichita
GY3
Wichita
Curious to see if those work out.
Real world application vs. beautiful sculpture..
#1354521
04/05/15 09:26 PM
04/05/15 09:26 PM
fullmetaljacket
Well, I took a hooky break to install my titanium front wheel lug studs on the aluminum brake drum hub. Saved almost 12 ounces or 3/4 Lb between the both sides. A few other things that I have done at the beginning of the Winter has now put the car solidly in the upper 3000 LB mark. For now, I'll exorcise it from its cave and have some limited fun in the sun during the season. It will be within striking distance of 2900 lbs by next Spring. That will be my cap.
#1798295
04/08/15 04:45 AM
04/08/15 04:45 AM
Posts: 4,862 the frozen wastes...
Pale_Roader
Swears too much
Swears too much
Well, the industry has come a long way since the wicked Witch from the West melting aluminum exhaust headers formed for the Swiss cheese Catalina's. The aluminum now being used is of the T-356 type and can probably take more heat. I still would be nervous with them taking full open throttle bursts up and down the track. For the money, I'd rather opt for Titanium exhaust tubes that can take the heat and are most probably just as light because of the thinner gauge construction. For now, I'll stick with my thin steel headers. I'd imagine the titanium tubes would be a lot louder. Just like the thinner (old school Hooker headers used thinner gauge (for more internal area than competing brands), and were noticeably louder... and in my opinion sounded worse... they sounded cheap. A thin, strong titanium pipe would have to be louder. It was an eye-opener when i replaced my Mustang's (non-stock) mild steel tails with the factory (same size) stainless. The factory SS was thick, and thats why they sound really good. A really thin SS (or thinner yet titanium) would sound more like a cheap header. IF... ov course, that matters to you. I am as anal and obsessive about weight as even you are (believe it), but i DO draw the line at sound. Its gotta sound good. Just a thought.
