Re: 1970 rr help [Re: hemipowered2] #179776
01/03/09 01:16 AM
01/03/09 01:16 AM
RI Deep in the rust belt
chargervert Offline
chargervert  Offline
I'd measure the distance from the rear crossmember,to the hole in the frame rail,where the shackle mount, on both Road Runners,and see if there the same distance,that should tell you if the replacement rails are correct,compared to the car that the springs fit in correctly.
70 Charger R/T SE 472 Hemi 70 Charger R/T convertible 70 Charger R/T V Code Sixpack 69 Charger R/T SE Sunroofcar 68 Charger 383 68 Charger 318 71 Charger R/T 70 Challenger convertible 71 Challenger convertible 71 Cuda 340 09 Challenger R/T Classic
Re: 1970 rr help [Re: chargervert] #179777
01/03/09 04:19 AM
01/03/09 04:19 AM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
i bought espo 1" over leal springs for my 70 road runner,found easiest way to install was loosly mount the front of the leaf springs with the one through bolt,leaving the back of the springs on the floor,rolled my rear under car and bolted the U clamps on each side,with a floor jack i jacked up the rear and bolted up the shackles,although they appeared slightly leaning forward once everything else was mounted they relaxed and i loosed jounced and retightened. i can take some measurements if you need,my frame is original. good luck Darren
Re: 1970 rr help [Re: meepmeep70] #179778
01/03/09 09:08 AM
01/03/09 09:08 AM
Jacksonville, Fl
426runner Offline
426runner  Offline
Jacksonville, Fl
I am using the +2" set from Espo. The rear just barely hooked up-
But with weight on the springs they settled right into position-
Later, Sandy '70 HEMI Road Runner B5/B5, 4 spd "Sandy's Garage" on Facebook
Re: 1970 rr help [Re: 426runner] #179779
01/03/09 05:51 PM
01/03/09 05:51 PM
USA
hemipowered2 Offline OP
USA
well i got the leafspings in funny thing is. can someone tell me which side is suppose to be the 7 leaf and which side should have the 6?? the passenger side has the 6 in it now. is this wrong?
Re: 1970 rr help [Re: hemipowered2] #179780
01/03/09 06:31 PM
01/03/09 06:31 PM
colorado
a12superbee Offline
a12superbee  Offline
colorado
Shouldn't you have checked that before you argued with them for a week? The pass side gets the extra leaf.
Laughing with you, not at you.
I can't afford this. mark
Re: 1970 rr help [Re: hemipowered2] #179781
01/03/09 06:35 PM
01/03/09 06:35 PM
St. Louis, MO
DodgeMaterial Offline
St. Louis, MO
Extra leaf goes on the "traction" (passenger) side. Good Luck! Dave
DodgeMaterial - Dave JS29U0B - FK5 - 440-4 Auto WS23V0A - EB5 - 440-6 Auto
Re: 1970 rr help [Re: DodgeMaterial] #179782
01/03/09 06:59 PM
01/03/09 06:59 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
What did you have to do to get them to bolt up??
Re: 1970 rr help [Re: hemipowered2] #179783
01/03/09 08:19 PM
01/03/09 08:19 PM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
Oops...I guess putting them in for the second time should be easier right....
Passenger side always gets the extra leaf...
CHECK OUT MY NEW WEB SITE !
Re: 1970 rr help [Re: hemipowered2] #179784
01/04/09 12:27 AM
01/04/09 12:27 AM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
Congratulations! What did you have to do to get the shackles in? Can you post a photo? I'm curious to see how the angle at the rear shackle looks?
Re: 1970 rr help [Re: RoadRunnerJD] #179785
01/04/09 12:10 PM
01/04/09 12:10 PM
PA.
3
340rocks Offline
340rocks  Offline
PA.
set the car level give us measurments then go from threr
Re: 1970 rr help [Re: 340rocks] #179786
01/04/09 11:41 PM
01/04/09 11:41 PM
USA
USA
this is how they went in, no bushing in the leafspings or the shackles, and the shackles are borrowed from a buddie he has the new ones i was tring to get in before, these are from something but not my car..
Re: 1970 rr help [Re: hemipowered2] #179787
01/06/09 10:57 AM
01/06/09 10:57 AM
CT
harryhood Offline
Kermit
harryhood  Offline
Kermit
CT
Hey hemipowered2, I saw this posted in reference to your situation. This is someone else's suggestion as to the problem. I'm just posting it in the hope that it may help you out.
on 68-70 bbodys there are differances between dodges and plymouths
when you change out the frame rails they are the same.
what is not the same is the mounting points of the rear springs
when you change that part you need to know which one you are using..
the rear springs are the exact same on both ply and dodge
what is different between dodge and ply
is this and i will use ebarf to show you...
http://cgi.ebay.com/ebaymotors/New-Mopar...sspagenameZWDVW
thats 2 different parts....one for dodge and one for plymouth
obviously when he changed the rails he changed his mounting position
he just needs to use the right parts that will fit so
it will go back together correctly
Re: 1970 rr help [Re: harryhood] #179788
01/06/09 01:57 PM
01/06/09 01:57 PM
Bucks County, PA
500Stroker Offline
500Stroker  Offline
Bucks County, PA
Atta Boy Harry
Re: 1970 rr help [Re: 500Stroker] #179789
01/06/09 03:28 PM
01/06/09 03:28 PM
Atta Boy Harry
X2
Re: 1970 rr help #179790
01/06/09 08:01 PM
01/06/09 08:01 PM
PA.
3
340rocks Offline
340rocks  Offline
PA.
hey hemipower did you get bushings and shackles from buddy wheres are measurments
Re: 1970 rr help [Re: harryhood] #179791
01/07/09 07:27 PM
01/07/09 07:27 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
the fly in that ointment is that the DODGE hangers are LONGER than the plymouth hangers so if he had the wrong hangers , dodge on a plymouth it wouldn't be too short .
what i would do is put a piece of wood that will fit between the shackles between the frame and the spring and lower the body till you can get the shackle into the spring and the frame WITH THE BUSHINGS INSTALLED . then get all the weight on the springs so you can get the piece of wood out .
if that doesn't work then I would have to think something wasn't measured properly or the jig was off ???
Re: 1970 rr help [Re: JohnRR] #179792
01/07/09 08:54 PM
01/07/09 08:54 PM
PA.
3
340rocks Offline
340rocks  Offline
PA.
hey johnrr thats what i was going to tell him i think that will work
