Air Bleed (?) Plugs for 68 440 AVS 4429S - Source?
#1797084
04/06/15 01:52 AM
04/06/15 01:52 AM
Posts: 4,204 Fort Worth, TX
Clair_Davis
Fort Worth, TX
I'm going through the original AVS for my Sport Fury's 440 (4429S), and it appears that I'm missing the plugs the cover the air bleed passages: A8_4429S_Carb_Restore-22 by clair_davis, on Flickr A8_4429S_Carb_Restore-23 by clair_davis, on Flickr A8_4429S_Carb_Restore-24 by clair_davis, on Flickr I rebuilt this carb right after getting the car (back in 2005), and frankly I don't remember if the plugs were in place or not. I can't imagine it would run right if they weren't in place, and I only pulled the original carb because the choke wasn't working right. The new rebuild kit doesn't have them in it, and I don't have another AVS sitting around. I'd like to know if there are replacements out there, or if I have to cook some up on the lathe. Shouldn't be too tough, but will take some time I could put elsewhere. Thanks! Clair
Re: Air Bleed (?) Plugs for 68 440 AVS 4429S - Source?
[Re: Clair_Davis]
#1797184
04/07/15 10:49 AM
04/07/15 10:49 AM
Posts: 3,916 usa
lewtot184
usa
doing some thinking and i need to make a "correction". those are not mixture screw plugs. somebody corrected me on this, their reply is missing, and they were right. those plugs cover the transfer slot machining. i took a pic of plugs i pulled out of a junk carb. they'er alum, but a piece of lead will work.
sorry, with the new stuff i can't get a picture to load.
[Re: Clair_Davis]
#1797249
04/07/15 12:05 PM
04/07/15 12:05 PM
Clair_Davis
Fort Worth, TX
Strange - some posts are missing. Unfortunately, I found a photo I took a couple weeks after I bought the car and it clearly shows the plugs in place: Sooooo... it's my bad that they're missing. Oops. Got most of one finished on the lathe last night, but if that doesn't work I'll look in to some other options. Rats... Clair
[Re: Clair_Davis]
#1797407
04/07/15 02:28 PM
04/07/15 02:28 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
https://buy.walkerproducts.com/carbureto...components.htmlThey have two size lead balls, 1/4" and 19/64" I believe. 83-4 LEAD BALL ( 1/4” ) 83-6 LEAD BALL ( 19/64” ) If either will work you can get it from them.
[Re: Clair_Davis]
#1797763
04/07/15 07:55 PM
04/07/15 07:55 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Strange - some posts are missing. Unfortunately, I found a photo I took a couple weeks after I bought the car and it clearly shows the plugs in place: Sooooo... it's my bad that they're missing. Oops. Got most of one finished on the lathe last night, but if that doesn't work I'll look in to some other options. Rats... Clair Name and address will get you what you need !!
