For the first time since 2011............. #1796993
04/05/15 09:50 PM
04/05/15 09:50 PM
BROOK PARK, OH
WILD BILL Offline OP
BROOK PARK, OH
It looks like I'm actually gonna get to race again.
I spent yesterday going through everything and today priming the oil system and changing the plugs and de winterizing the car.
It fired off like she was pissed I left her sit so long
But the real reason for this post is to get some input from you guys.
In taking the dist and the oil pump drive gear out to prime it I marked the location and orientation of everything and so I'm pretty confident that the timing is at least pretty darn close to where it should be but still wanted to set it to make sure.
This is where I ran into something I've never experienced before.
While the light strobing from the gun looked normal, it did not show the steady display of the numbers on the balancer like it should. It looked like the balancer was jumping all over the place.
Now, the light in question is a Craftsman Pro dial back light. I know I have used this light without issue before both on my car and my wifes.
The cars ignition system is an MSD 6AL, MSD billet dist (locked adv) and Firecore wires and coil.
I have read all the posts about dial back timing lights not working with MSD ign's but as this is the first time I've ever run into this I need to ask if this sounds like the timing light is the issue or does it sound like something is going on with my ign system?
Re: For the first time since 2011............. [Re: WILD BILL] #1796994
04/05/15 09:53 PM
04/05/15 09:53 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Can you borrow a friends timing gun? Glad you're getting back at it, it's been since September 2010 that I went down a track.
Re: For the first time since 2011............. [Re: WILD BILL] #1796995
04/05/15 10:02 PM
04/05/15 10:02 PM
Az
Crizila Offline
Crizila  Offline
Az
Looked inside the distributor lately? Maybe it's a little rusted up?
Fastest 300
Re: For the first time since 2011............. [Re: Crizila] #1796996
04/05/15 10:24 PM
04/05/15 10:24 PM
ohio
67mprfan Online content
67mprfan  Online Content
ohio
Are the dist wires hooked up correctly mine were backwards caused timing light to read incorrectly
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: For the first time since 2011............. [Re: Crizila] #1796997
04/05/15 10:25 PM
04/05/15 10:25 PM
BROOK PARK, OH
BROOK PARK, OH
I had the dist cap off during the procedure and saw no rust or anything else out of the ordinary.
I did have my dad go get his old Sun timing light and it did the same thing.
Re: For the first time since 2011............. [Re: 67mprfan] #1796998
04/05/15 10:27 PM
04/05/15 10:27 PM
BROOK PARK, OH
BROOK PARK, OH
The plug only fits together one way.
No way to screw it up
Re: For the first time since 2011............. [Re: WILD BILL] #1796999
04/05/15 10:45 PM
04/05/15 10:45 PM
tboomer Online work
tboomer  Online Work
Good luck to you this year blue boy! How's the new job treatin ya!
Re: For the first time since 2011............. [Re: WILD BILL] #1797000
04/05/15 10:49 PM
04/05/15 10:49 PM
Lowes
steve660 Offline
steve660  Offline
Lowes
Mine has done that. Timing mark jumps around. Mine was Timing chain stretch.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure.
..... Now its a door stop....
Re: For the first time since 2011............. [Re: steve660] #1797001
04/05/15 11:03 PM
04/05/15 11:03 PM
BROOK PARK, OH
BROOK PARK, OH
I got my car running so I guess it's going pretty good Ted
Hard to believe it would be chain stretch with only a short season of run time.
Re: For the first time since 2011............. [Re: WILD BILL] #1797002
04/05/15 11:12 PM
04/05/15 11:12 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
What type of damper do you use?
What brand of timing chain set, too?
Re: For the first time since 2011............. [Re: WILD BILL] #1797003
04/05/15 11:32 PM
04/05/15 11:32 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
With MSD ignitions we up the RPM to over 3,000 before using the timing light. And I'll be expecting a hug at Norwalk this fall!
Re: For the first time since 2011............. [Re: dustergirl340] #1797004
04/05/15 11:37 PM
04/05/15 11:37 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Run the engine up over 3000. IIRC that is where an MSD goes to single strike. It should then firm up the strobe if it's the light objecting to the MSD at idle.
Kevin
Re: For the first time since 2011............. [Re: Twostick] #1797005
04/05/15 11:45 PM
04/05/15 11:45 PM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
Check to make sure everything is tight in distributor. I had the same problem with mine, and screws in rotor were loose. Not saying that's the problem, but something to check.
Re: For the first time since 2011............. [Re: BradH] #1797006
04/05/15 11:48 PM
04/05/15 11:48 PM
BROOK PARK, OH
BROOK PARK, OH
The damper is a Profesional Products.
I don't recall 100% on the chain but I think it's a Cloyes.
Re: For the first time since 2011............. [Re: moparguy7074] #1797007
04/05/15 11:55 PM
04/05/15 11:55 PM
BROOK PARK, OH
BROOK PARK, OH
I'll double check the rotor screws. and try over 3K RPM. Not sure I can get away with that in the neighborhood though. Might have to wait till we're at the track for that.
Kathy, Not sure I'm going to do the Mopar race at Norwalk. Not sure I can get that time off this early in the new job plus I can't seem to wrap my head around justifying what they are charging for weekend vs what it used to be. I know it's a different event and hoster but still........
Re: For the first time since 2011............. [Re: WILD BILL] #1797008
04/06/15 12:35 AM
04/06/15 12:35 AM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Bill,
The cost is $150.00 for the weekend and you get 2 FULL race days with 2 FULL payouts! You never got that much with the person that was running it before
Re: For the first time since 2011............. [Re: max_maniac] #1797009
04/06/15 12:49 AM
04/06/15 12:49 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Heck of a deal Bill for a weekend race like that
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: For the first time since 2011............. [Re: WILD BILL] #1797010
04/06/15 01:02 AM
04/06/15 01:02 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
always good to hear about another ride coming out of mothballs! hope you are able to beat on that ride this summer!! treat R like ya beat R!
Re: For the first time since 2011............. [Re: J_BODY] #1797011
04/06/15 05:37 AM
04/06/15 05:37 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Glad to hear you"re back!
Re: For the first time since 2011............. [Re: WILD BILL] #1797012
04/06/15 06:15 AM
04/06/15 06:15 AM
Bloomingdale , OH
super451b Offline
super451b  Offline
Bloomingdale , OH
Welcome Back ! I use the same light without any issues. 2 things that I have seen are
1. The pickup for the timing light is too close to one of the other wires.
2. Timing chain stretch
