Hemi spark plugs
#1794352
04/01/15 06:16 PM
04/01/15 06:16 PM
Posts: 1,132 Home of the Bluegrass
MoparJunkie
Hey guys, finally getting ready to fire the hemi up and I want to know if NGK BP7ES plugs will be okay? 472 with eddy aluminum heads, 10.5 cr, with 587/564 hydraulic cam... They're 13/16 hex plugs just want to make sure the reach is correct????? TIA
"It takes a Mopar to catch a Mopar” 1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54 2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
Re: Hemi spark plugs
[Re: sunroofgtx]
#1794359
04/03/15 11:11 PM
04/03/15 11:11 PM
MoparJunkie
Rick, should I use the 5/8's or 13/16's??? I forgot what we discussed????
[Re: MoparJunkie]
#1794360
04/06/15 02:35 AM
04/06/15 02:35 AM
Posts: 193 Australia
Teamx
Australia
Stick with the 13/16 plugs as they are the correct length for the plug boot. The 7 is a cold plug for your combo start with a 6 if its going to see a lot of idling you could even go with a 5.Dont forget to cut the washers off the plugs!
[Re: super451b]
#1798045
04/07/15 11:41 PM
04/07/15 11:41 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
If your chambers have been worked/cnc'd , you may want to find a way to see exactly how long of a reach plug that you need. I have a set of BB RPM heads in the shop now that have had the chambers cnc'd and because of the material that was removed , the threads for standard .750 reach plug ,for that head, now protrude an 1/8" into the chamber. While I dont think that would cause any clearance issues, it will affect how well you plug will dissipate heat. So with the plugs sticking into the chamber 1/8 inch, do you just stack washers on the plug to correct the depth? Leaving them long , the threads will carbon up and either pull the treads upon removal or break off the plug. What's it going to be?
[Re: MoparJunkie]
#1801526
04/12/15 08:29 AM
04/12/15 08:29 AM
Posts: 1,629 pa
572charger
pa
i use autolites in my hemi 65's hot for drivin around 64's race on motor and 63's for the spray on pumpgas !!!!! hope this helps , they are cheap also like 14.94 for a set of 8 !!!!
606 hemi pump gas best 9.60 at 142mph on motor 05 hemi daytona 1500 go-mango 4wd quadcab 2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
