Hemi spark plugs #1794352
04/01/15 06:16 PM
04/01/15 06:16 PM
Home of the Bluegrass
MoparJunkie Offline OP
Hey guys, finally getting ready to fire the hemi up and I want to know if NGK BP7ES plugs will be okay? 472 with eddy aluminum heads, 10.5 cr, with 587/564 hydraulic cam... They're 13/16 hex plugs just want to make sure the reach is correct?????
TIA
"It takes a Mopar to catch a Mopar”
1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54
2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
Re: Hemi spark plugs [Re: MoparJunkie] #1794353
04/01/15 06:35 PM
04/01/15 06:35 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
I can't say as far as the heat range, but if it's the long reach (long threaded area) like this one pictured it should be correct.
Re: Hemi spark plugs [Re: MoparJunkie] #1794354
04/01/15 06:39 PM
04/01/15 06:39 PM
What does Eddy say about he correct spark plug length? Follow thier directions
If they say to use a standard 426 Gen 2 spark plug type your golden with that plug as long as it is 3/4 reach I like and use the smaller 5/8 hex spark plugs now instead of the larger 13/16 OEM sizes
Re: Hemi spark plugs [Re: MoparJunkie] #1794355
04/01/15 06:51 PM
04/01/15 06:51 PM
California
mickm Offline
mickm  Offline
California
NGK BP6ES is what i've always used, and heard recommended by a number of hemi people. of course, that is a starting point. i've never tried other heat ranges. plugs look good, so no need, but
Re: Hemi spark plugs [Re: MoparJunkie] #1794356
04/01/15 10:44 PM
04/01/15 10:44 PM
Bloomingdale , OH
super451b Online content
super451b  Online Content
Bloomingdale , OH
If your chambers have been worked/cnc'd , you may want to find a way to see exactly how long of a reach plug that you need. I have a set of BB RPM heads in the shop now that have had the chambers cnc'd and because of the material that was removed , the threads for standard .750 reach plug ,for that head, now protrude an 1/8" into the chamber. While I dont think that would cause any clearance issues, it will affect how well you plug will dissipate heat.
Re: Hemi spark plugs [Re: super451b] #1794357
04/01/15 11:06 PM
04/01/15 11:06 PM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
BR8ES
Re: Hemi spark plugs [Re: OUTLAWSSAA] #1794358
04/03/15 09:25 PM
04/03/15 09:25 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Don't forget. If you switch to a 5/8ths plug, the wire set might not work. The 13/16ths plug is 1/4 inch taller.
Re: Hemi spark plugs [Re: sunroofgtx] #1794359
04/03/15 11:11 PM
04/03/15 11:11 PM
Rick, should I use the 5/8's or 13/16's??? I forgot what we discussed????
Re: Hemi spark plugs [Re: MoparJunkie] #1794360
04/06/15 02:35 AM
04/06/15 02:35 AM
Australia
Teamx Offline
Teamx  Offline
Australia
Stick with the 13/16 plugs as they are the correct length for the plug boot. The 7 is a cold plug for your combo start with a 6 if its going to see a lot of idling you could even go with a 5.Dont forget to cut the washers off the plugs!
Re: Hemi spark plugs [Re: super451b] #1798045
04/07/15 11:41 PM
04/07/15 11:41 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
So with the plugs sticking into the chamber 1/8 inch, do you just stack washers on the plug to correct the depth? Leaving them long , the threads will carbon up and either pull the treads upon removal or break off the plug. What's it going to be?
Re: Hemi spark plugs [Re: MoparJunkie] #1801526
04/12/15 08:29 AM
04/12/15 08:29 AM
pa
572charger Offline
572charger  Offline
pa
i use autolites in my hemi 65's hot for drivin around 64's race on motor and 63's for the spray on pumpgas !!!!! hope this helps , they are cheap also like 14.94 for a set of 8 !!!!
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
