500 CI RB SIX PACK HELP
#1792782
03/31/15 07:37 PM
03/31/15 07:37 PM
Posts: 85 Washington PA
69 plymouth rnr
Washington PA
Im having trouble setting up my stroker six pack, jets,meetering plates,ect list of parts new hollry carbs new ported intake 640 solid lift cam / 256 duration HUGHES APROX 11.2.1 COMPRESSION EDDY RPM PORTED 2.19 INT Any help dialing in is appreciated. Thanks Nick
Re: 500 CI RB SIX PACK HELP
[Re: Mr.Yuck]
#1792788
04/01/15 01:08 AM
04/01/15 01:08 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Lock your timing at 36* 70 jet is to much. I ran 65 The floats hit the promax plates when I got them. Run a 6.5 PV. Adjust your af scews on front carb and set the rear the same Put a 50cc pump and 35 squirter. Dont mess with the pod springs You can change jetting on the outboard with a drill bit. I had mine similar to what is in the old DC race manual
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#1792793
04/01/15 10:27 PM
04/01/15 10:27 PM
69 plymouth rnr
Washington PA
Ok , well im going to put the light on to when its running ,and the springs are just one of the things im throwing at it .When it goes back together this weekend it will be as follows.... quick fuel plates 70 jets in center 50cc pump blue cam 2.5 power valve 84 jets front and rear and go from here ?
[Re: 69 plymouth rnr]
#1792794
04/01/15 10:36 PM
04/01/15 10:36 PM
Posts: 2,230 restos just aren't my thing
gtsuperbee
So many things to check. start with just making sure they open and close completely (each one by themselves) when you bolt them down. The can hang up on gasket material easily and make sure all your linkage is functioning correctly before you even start to tune. Also, keep in mind, all 3 carbs work as one for tuning, meaning you can't just make a set of block off plates for the outboard carbs and start tuning just the center carb.
Restoring a car to look "only" as good as the factory made it is like getting a boob job for your wife and having the doctor make them two different sizes to seem more natural
#1792796
04/02/15 01:07 AM
04/02/15 01:07 AM
Posts: 1,305 Lakewood, Colorado
herkamer
Lakewood, Colorado
Been fighting some of the same issues with mine on the 360. I have a pretty radical cam which I don't know the specs on. They need more fuel at idle, I am 2 turns out on the outboard needles and it's still a bit lean. Runs much better and tamed the idle with more fuel. With the jettable plates you might be able to circumvent some of that. Read the old article about halfway down this page: http://www.mopar1.us/6barreltips.htmlIt's 7 pages and really details the theory of operation and good tuning tips.
Matt 69 Dart Swinger 340 83 W350, Megasquirted with 46RH Old news: 72 Demon street/race mobile Latest: 70 Duster backhalf car and even more
#1792797
04/02/15 01:08 AM
04/02/15 01:08 AM
Posts: 43,126 Bend,OR USA
Cab_Burge
UPDATE!!!! HOLLEY 4792 AND 4790 CARBS AND YES POWER VALVE MIGHT TRY A 2.5
Do these carbs. have the List #4790 and List # 4792 or are they List # 4790-1 or -2 and 4792-1 or -2 or no dash numbers after the list numbers? The reason I'm asking is the original OEM carbs did not have dash #s, only the later Holley replacement carbs have the -1 or -2 #s after the list numbers. I have had expereinces with both types and the later -1 and -2 are harder to get them dialed in and running good I saw that you had bought them from Summit recently so you can count on them being the later replacement -1 and -2 carbs Holley made, not the early ones Ma Mopar bought and installed on the cars back when What is the center carb. List #? I have seen many guys on this web site advice using combinations of jets and squirters that would not work on any of the sixpak set ups I have tuned and used on street cars out here and in SO CA My message here is the place you live and work on your car at can have a direct effect on what tuning your carbs. need I live west of the Rocky Mtns at 3500 + ft altitude, the humidity here is a bunch lower than the same elevation in many states east of the rockies, humidity plays a big factor on how close the oxygen molicules are in the air where you live and drive Same thing on barometric pressures and temperatures. BTW, all us drag racers and Hi Po Mopar street guys west of the rockies suck all the good air out of the atomsphere before we let it circulate back east, right Thumper, Triple Threat and Jeremiah It is still 04-01-2015,isn't it
