magnum 160,000 miles 5.7 Hemi too many miles? #1789760
03/27/15 11:12 PM
03/27/15 11:12 PM
wisconsin united states
K
keith airgrabber Offline OP
Right in the Nutz!!!
K
Kind of a dumb question. But is 160,000 miles alot for the 5.7. Hemi. I am contemplating buying a 2005 Magnum for 6,600 bucks. I think that is kind of high. Is that just what these cars bring even with high miles.It sure is hard to find a hemi magnum. especially unmolested and with lower miles.
Re: magnum 160,000 miles 5.7 Hemi too many miles? [Re: keith airgrabber] #1789761
03/27/15 11:30 PM
03/27/15 11:30 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I don't think so, I have 221k on a 4.7
Re: magnum 160,000 miles 5.7 Hemi too many miles? [Re: keith airgrabber] #1789762
03/27/15 11:55 PM
03/27/15 11:55 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Magnums seems to hold their value, 5.7's can go a lot of miles
Re: magnum 160,000 miles 5.7 Hemi too many miles? [Re: WO23Coronet] #1789763
03/27/15 11:58 PM
03/27/15 11:58 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I have 150k on my 03 Ram and it still runs great and no leaks, no smoke, no noises and good oil pressure.
Re: magnum 160,000 miles 5.7 Hemi too many miles? [Re: stumpy] #1789764
03/28/15 12:19 AM
03/28/15 12:19 AM
IN
ahy Offline
ahy  Offline
IN
I ran my last 5.7 Durango to 165k. Performance and oil consumption were as new. My current one has about that and I plan to go to 200k at least. Both needed a water pump around 140k. The prior needed a fan clutch. The latest needed an exhaust manifold (warped) around 100k. That's it. The 5.7 seems to age very well.
A Magnum, driven reasonably and maintained, should do better as there is less load. There will be more maintenance at higher miles but I think no basic issues with the engine.
Re: magnum 160,000 miles 5.7 Hemi too many miles? [Re: ahy] #1789765
03/28/15 12:58 AM
03/28/15 12:58 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
I have an 06 Magnum R/T AWD, with 110k miles on it now - never any issues with the 5.7. Although if you have a bit of surge at idle, and sometimes it wont start up right away, replace the cam sensor - up by the thermostat housing - way easy to do !! Won't be throwing any codes off, but once you replace it, rock steady idle and always easy starting. My car still have 50psi oil pressure when you get over 1500 rpm. 20psi at idle. . . everything works great. This was my company car and I have been only driver . . . if the car is in good shape, go for it . . .
Mark
Re: magnum 160,000 miles 5.7 Hemi too many miles? [Re: keith airgrabber] #1789766
03/28/15 01:31 AM
03/28/15 01:31 AM
Alberta
N
NEVjr Offline
NEVjr  Offline
N
Alberta
mine is at about 140k miles, in an 04 durango. its on its third alternator, and has an exhaust leak on the rear drivers side cylinder due to a header bolt working loose, it was not possible to put the special clip on the bolt on that one and its worked loose. otherwise, its just recently its needed the throttle body cleaned. still runs good and drives fine.
Re: magnum 160,000 miles 5.7 Hemi too many miles? [Re: NEVjr] #1789767
03/28/15 04:08 AM
03/28/15 04:08 AM
A Red State
SNK-EYZ Online tonguue
SNK-EYZ  Online Tonguue
A Red State
The 5.7 Hemi's can go lots of miles if maintained decently.
My 2004 Ram 2500 with a 5.7 Hemi has 280,000 miles on it now and still runs great and only uses a quart of oil about every 4,000 miles.
Re: magnum 160,000 miles 5.7 Hemi too many miles? [Re: keith airgrabber] #1789768
03/28/15 03:48 PM
03/28/15 03:48 PM
Earth
Rob C Offline
Rob C  Offline
Earth
My examples are not HEMI engines but I think they are good examples of the modern tech doing what they should be doing. Delivering!
My '03 quad cab 4X4 Dakota V6 has 220,000 mile plus and uses less than half a quart of oil between the oil changes. Still gets 19/20 Hwy.
The wife's '99 Durango has more mileage. Does use a little more oil than mine does though.
No leaks on ether engine. They run like an old sewing machine. Solid as a rock. Modern engine with high miles really do not scare me. Prior maintainence or lack there off is the pit fall.
Re: magnum 160,000 miles 5.7 Hemi too many miles? [Re: Rob C] #1789769
03/28/15 04:15 PM
03/28/15 04:15 PM
Long Island, NY USA
BergmanAutoCraft Offline
Long Island, NY USA
I've got 180K on my 05 Magnum RT. Its bone stock and still runs like new.
Re: magnum 160,000 miles 5.7 Hemi too many miles? [Re: BergmanAutoCraft] #1789770
03/28/15 08:35 PM
03/28/15 08:35 PM
Great White North
Furyman Offline
Furyman  Offline
Great White North
Ditto..the wifes 06 R/T has 180k on it...still strong and uses no oil.The front ends though ,I think we are on the 3rd complete rebuild...too much backroading.
"Long Live Mopars"
Re: magnum 160,000 miles 5.7 Hemi too many miles? [Re: keith airgrabber] #1789771
03/29/15 12:44 AM
03/29/15 12:44 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
160k miles for a new engine is nothing to sweat over. The rest of the car on the other hand may be ready for some repairs. Hear about front end problems with those cars. Haven't seen any running around with the same rust issues the same era rams have.
Re: magnum 160,000 miles 5.7 Hemi too many miles? [Re: DaytonaTurbo] #1789772
03/29/15 01:29 AM
03/29/15 01:29 AM
Great White North
Furyman Offline
Furyman  Offline
Great White North
My 06 has rusted through on the end of the right rear quarter where it meets the bumper cover.Rest of car still clean.
"Long Live Mopars"
