Re: Replaced plenum gasket, now trans is slipping?
[Re: SattyNoCar]
#1787046
03/26/15 07:09 PM
03/26/15 07:09 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
On vacation... Not spending much time on interwebz this week.
Sounds like you got it all sorted out though!! Even if your truck doesn't have a white clip on the TV cable! Lol
How much have you replaced on the truck? Have you checked the cap n rotor on the distributor? Still running stock wires? Rick makes a nice set of wires for these magnum motors.
**Photobucket sucks**
[Re: 70Cuda383]
#1787047
03/26/15 07:25 PM
03/26/15 07:25 PM
Posts: 16,896 Between Houston & Galveston TX
SattyNoCar
How much have you replaced on the truck? Have you checked the cap n rotor on the distributor? Still running stock wires? Rick makes a nice set of wires for these magnum motors. Oh, so you missed the pics I posted in the other thread........... Here they are for your viewing pleasure. Rotor that was on the truck next to a new one: And where it smacked the cap: The rotor tip was pushed over like that when I pulled the cap. Amazingly it didn't have misfire. Wires, I went with a set from Advance Auto already as I had a coupon. The truck runs soooooooo much better now, its like a different truck. I may have to learn how to 'drift' though. Any kind of wetness or dirt on the road and this thing WILL kick out.
John
[Re: 79powerwagon]
#1787050
03/27/15 12:38 AM
03/27/15 12:38 AM
70Cuda383
Marysville, O-H-I-O
My gen 3 with a stick shift 5.2, intake, cam, headers, SCT was running 17.5. That same set up was good for 14.6 in the 1/4 mile. My 5.9 with eddy heads is closer to 14 mpg, but I can't keep my foot out of it
A gen 2 is lighter, it should do better than a gen 3
[Re: SattyNoCar]
#1787052
03/27/15 07:30 PM
03/27/15 07:30 PM
Posts: 12,478 Kalispell Mt.
HotRodDave
Kalispell Mt.
I just swapped in a set of 4.6 5.4 5.0 yellow ford injectors and picked up a couple mpg in my 99 5.2 5 speed, I have it up to the same mpg as my last V6 5 speed truck did. I have also added cold air intake, electric fan, 17" RT wheels with narrow tall low rolling resistance tires. The injectors made the biggest difference and cost me $50 at the local JY and 30 minutes to install. Idle is smoother and I can lug it around at lower RPM now without chugging.
[Re: SattyNoCar]
#1787053
03/27/15 07:33 PM
03/27/15 07:33 PM
HotRodDave
Kalispell Mt.
On an automatic you can usually slot the crank sensor and advance the timing a couple degrees for a free MPG trick. On both of my last 5 speed trucks it caused too much pinging unless I ran premium with no MPG increase.
[Re: HotRodDave]
#1787054
03/29/15 10:00 AM
03/29/15 10:00 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
I just swapped in a set of 4.6 5.4 5.0 yellow ford injectors and picked up a couple mpg in my 99 5.2 5 speed,......Idle is smoother and I can lug it around at lower RPM now without chugging.
The Yellow top Ford injectors have 4 spray holes?
They are rated 24 lb/hr at 43 psi ( or maybe 19) ?
Does anyone know of 12 hole injectors available on vehicles in junk yards that are in the 24 to 34 lb/hr range?
Seems like i remember that Denso makes 12 hole injectors that make 60 micrometer droplets that are standard on some Kawasaki products.
[Re: 360view]
#1787055
03/29/15 10:44 AM
03/29/15 10:44 AM
Posts: 8,082 Tulsa OK
Bad340fish
Tulsa OK
I thought the yellows were 19lb, I have some ford 24lbs in the stroker 4.0 in my jeep, they are blue. I have some 42lb injectors for my barracuda and they are green.
68 Barracuda Formula S 340
