Re: Replaced plenum gasket, now trans is slipping? [Re: SattyNoCar] #1787043
03/25/15 05:22 PM
03/25/15 05:22 PM
missouri, USA
moparmojo Offline
moparmojo  Offline
missouri, USA
Glad to hear your truck is doing better. I might suggest you take this opportunity to clean our replace your iac. I had my plenum gasket replaced a couple years ago then last year had what I thought was the same problem. However I found it was a dirty struck iac. Cost $25 for a new one and was 100% better. Just preventative maintenance is my suggestion.
Re: Replaced plenum gasket, now trans is slipping? [Re: moparmojo] #1787044
03/25/15 05:30 PM
03/25/15 05:30 PM
Between Houston & Galveston TX
SattyNoCar Offline OP
I gutted the throttle body and hit it multiple times with oven cleaner to get it clean. Cleaned the IAC while I had it off (with throttle body cleaner NOT oven cleaner ). It was so THICK with funk, I'm surprised it worked at all.
Re: Replaced plenum gasket, now trans is slipping? [Re: SattyNoCar] #1787045
03/25/15 05:41 PM
03/25/15 05:41 PM
I posted this over on the general board earlier today.....
This morning, I ran a few errands with the Dakota. Got done early so I decided to take a drive down to Galveston, partly to clear my head after all the fussing and cussing done over the Dakota the past few days.
I quickly realized three things......
1) First and foremost, the Dak is a TRUCK and rides like one.
2) This was the furthest I'd driven it since I bought it. Every little noise had me
3) Galveston wasn't far enough. It runs so good now, I'd like to take it on a roadtrip out to Austin or San Antonio. Maybe even back East if I get adventurous.
Haven't calculated it yet, but, my MPG has come up. Normally it hits half a tank at about 120-130 miles. Between last night's drive and I what I drove today, I've covered 112 miles, and its sitting dead on the 3/4 tank mark.
Just need to take care of a few more minor mechanical things, and I can start working on making it look good again.
Re: Replaced plenum gasket, now trans is slipping? [Re: SattyNoCar] #1787046
03/26/15 07:09 PM
03/26/15 07:09 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
On vacation... Not spending much time on interwebz this week.
Sounds like you got it all sorted out though!! Even if your truck doesn't have a white clip on the TV cable! Lol
How much have you replaced on the truck? Have you checked the cap n rotor on the distributor? Still running stock wires? Rick makes a nice set of wires for these magnum motors.
**Photobucket sucks**
Re: Replaced plenum gasket, now trans is slipping? [Re: 70Cuda383] #1787047
03/26/15 07:25 PM
03/26/15 07:25 PM
Oh, so you missed the pics I posted in the other thread...........
Here they are for your viewing pleasure.
Rotor that was on the truck next to a new one:
And where it smacked the cap:
The rotor tip was pushed over like that when I pulled the cap. Amazingly it didn't have misfire.
Wires, I went with a set from Advance Auto already as I had a coupon.
The truck runs soooooooo much better now, its like a different truck. I may have to learn how to 'drift' though. Any kind of wetness or dirt on the road and this thing WILL kick out.
John
Re: Replaced plenum gasket, now trans is slipping? [Re: SattyNoCar] #1787048
03/26/15 10:24 PM
03/26/15 10:24 PM
Filled up the tank, the new MPG number is.........15MPG...yes, FIFTEEN!!!
WooFeeakin'Hoo!!
I'm a VERY happy camper right now!!
Re: Replaced plenum gasket, now trans is slipping? [Re: SattyNoCar] #1787049
03/26/15 11:33 PM
03/26/15 11:33 PM
places
79powerwagon Offline
places
I still say dump a can of SeaFoam into the tank and run it through! Then get a good alignment, and you should be nearing 20mpg!
Re: Replaced plenum gasket, now trans is slipping? [Re: 79powerwagon] #1787050
03/27/15 12:38 AM
03/27/15 12:38 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
My gen 3 with a stick shift 5.2, intake, cam, headers, SCT was running 17.5. That same set up was good for 14.6 in the 1/4 mile. My 5.9 with eddy heads is closer to 14 mpg, but I can't keep my foot out of it
A gen 2 is lighter, it should do better than a gen 3
Re: Replaced plenum gasket, now trans is slipping? [Re: 70Cuda383] #1787051
03/27/15 01:10 AM
03/27/15 01:10 AM
If I can squeak some more MPG out of it, great! If not, as long as it stays around 15MPG I can live with it. My ol' (slow) Caravan gave me 16 in almost 100% in town driving.
Re: Replaced plenum gasket, now trans is slipping? [Re: SattyNoCar] #1787052
03/27/15 07:30 PM
03/27/15 07:30 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I just swapped in a set of 4.6 5.4 5.0 yellow ford injectors and picked up a couple mpg in my 99 5.2 5 speed, I have it up to the same mpg as my last V6 5 speed truck did. I have also added cold air intake, electric fan, 17" RT wheels with narrow tall low rolling resistance tires. The injectors made the biggest difference and cost me $50 at the local JY and 30 minutes to install. Idle is smoother and I can lug it around at lower RPM now without chugging.
Re: Replaced plenum gasket, now trans is slipping? [Re: SattyNoCar] #1787053
03/27/15 07:33 PM
03/27/15 07:33 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
On an automatic you can usually slot the crank sensor and advance the timing a couple degrees for a free MPG trick. On both of my last 5 speed trucks it caused too much pinging unless I ran premium with no MPG increase.
Re: Replaced plenum gasket, now trans is slipping? [Re: HotRodDave] #1787054
03/29/15 10:00 AM
03/29/15 10:00 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
I just swapped in a set of 4.6 5.4 5.0 yellow ford injectors and picked up a couple mpg in my 99 5.2 5 speed,......Idle is smoother and I can lug it around at lower RPM now without chugging.
The Yellow top Ford injectors
have 4 spray holes?
They are rated 24 lb/hr at 43 psi ( or maybe 19) ?
Does anyone know of 12 hole injectors
available on vehicles in junk yards
that are in the 24 to 34 lb/hr range?
Seems like i remember that
Denso makes 12 hole injectors
that make 60 micrometer droplets
that are standard on some Kawasaki products.
Re: Replaced plenum gasket, now trans is slipping? [Re: 360view] #1787055
03/29/15 10:44 AM
03/29/15 10:44 AM
Tulsa OK
Bad340fish Online content
Bad340fish  Online Content
Tulsa OK
I thought the yellows were 19lb, I have some ford 24lbs in the stroker 4.0 in my jeep, they are blue. I have some 42lb injectors for my barracuda and they are green.
68 Barracuda Formula S 340
