How to measure rally wheels? #1786756
03/23/15 07:25 PM
03/23/15 07:25 PM
Philadelphia, PA
GTXKARL Offline OP
GTXKARL  Offline OP
Philadelphia, PA
How do you measure rally wheels to see if its a fourteen or fifteen inch? Thank you.
Re: How to measure rally wheels? [Re: GTXKARL] #1786757
03/23/15 08:12 PM
03/23/15 08:12 PM
Northeastern PA
Fanning Offline
Fanning  Offline
Northeastern PA
With the tire not mounted you should be able to see the rim size stamped on the inside of the wheel hoop. If the tire is mounted on the rim just read the tire size on the sidewall of the tire. 205/75/R15 or F7015 would be a 15 inch wheel for example.
Re: How to measure rally wheels? [Re: Fanning] #1786758
03/23/15 08:27 PM
03/23/15 08:27 PM
Philadelphia, PA
GTXKARL Offline OP
GTXKARL  Offline OP
Philadelphia, PA
thank you
