Cam bearings R1A block #1786289
03/22/15 11:52 PM
03/22/15 11:52 PM
Hilltown Pa
1967dartgt Offline OP
Hilltown Pa
Looking for a place to buy cam bearings for my block. I have a 2" babbit bearing all the way through the block.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Cam bearings R1A block [Re: 1967dartgt] #1786290
03/23/15 12:44 AM
03/23/15 12:44 AM
San Antonio,TX
440W8 Duster Offline
San Antonio,TX
call Northern auto parts in Sioux City Ia 800-831-0884 and order the DuraBond PD-16 I believe or P4876372 ask for Matt Edwardson he can look them up to make sure. I used to work there in 09.
70 Duster W8 motor.
1.29 60ft 5.79 1/8 at 120 mph
glide with 1.80 gear
@3170 lbs.
Re: Cam bearings R1A block [Re: 440W8 Duster] #1786291
03/23/15 04:13 PM
03/23/15 04:13 PM
Hilltown Pa
Hilltown Pa
Thanks I will call today. Nobody else?
Re: Cam bearings R1A block [Re: 1967dartgt] #1786292
03/23/15 05:57 PM
03/23/15 05:57 PM
Hilltown Pa
Hilltown Pa
Matt no longer works there, left six months ago. The guy I talked to didn't know of them. The only ones he could find were for a dart little m block. Matt had sold a few sets to his father.
Re: Cam bearings R1A block [Re: 1967dartgt] #1786293
03/23/15 08:50 PM
03/23/15 08:50 PM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
Brad, I punched that part number into Google and this came up. Are these the ones you need?
Re: Cam bearings R1A block [Re: 1967dartgt] #1786294
03/23/15 10:20 PM
03/23/15 10:20 PM
San Antonio,TX
San Antonio,TX
OK I will find the part number.
70 Duster W8 motor.
@3170 lbs.
Re: Cam bearings R1A block [Re: 340_Dart] #1786295
03/23/15 10:54 PM
03/23/15 10:54 PM
Hilltown Pa
Hilltown Pa
That's what I ordered, but nobody can tell me if they are all the 2 in bearing. I just wonder if they are the set with the smaller one at the back.
Re: Cam bearings R1A block [Re: 1967dartgt] #1786296
03/24/15 10:35 AM
03/24/15 10:35 AM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
Let me know how it works out for you. I believe my R1A has 2" bearings front to back also.
Re: Cam bearings R1A block [Re: 340_Dart] #1786297
03/24/15 11:24 PM
03/24/15 11:24 PM
Hilltown Pa
Hilltown Pa
Ok
Re: Cam bearings R1A block [Re: 1967dartgt] #1798102
04/08/15 12:12 AM
04/08/15 12:12 AM
Hilltown Pa
Hilltown Pa
That is the correct part number for 2" babbit bearings.
Re: Cam bearings R1A block [Re: 1967dartgt] #1798281
04/08/15 02:48 AM
04/08/15 02:48 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
So you're all good to move forward on it?
