Re: Cam bearing- would you run it?
[Re: buildanother]
#1785411
03/22/15 03:11 AM
03/22/15 03:11 AM
Posts: 3,378 Rancho Cordova, CA
Exit1965
Rancho Cordova, CA
If the cam turns nice by hand, you can run it. I've seen ugly cam bearings out there.
I'd say that too. I have run ugly bearings.
Now, if you are taking the block to the machine shop, sure. If it's together and this is the only concern with the cam bearing, it's not really a concern in my experience.
[Re: Exit1965]
#1785412
03/22/15 11:56 AM
03/22/15 11:56 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Remember cams run at half the engine rpm.
That said, if the block is out and stripped down I'd just replace it since it won;t get easier or cheaper than right now.
[Re: 65Fury440]
#1785416
03/23/15 01:52 AM
03/23/15 01:52 AM
Posts: 75,071 U.S.S.A.
JohnRR
U.S.S.A.
I usually use Valvoline synthetic racing oil and zinc additive, but man, it's pricy. I think the last oil change I did on my 440 with a premium filter was right around $100.00
Use the non synthetic and you'll not need the additive , and it's cheaper. Atv oil will have a different additive package .
