why is a challenger longer than a cuda #1784827
03/21/15 01:23 PM
03/21/15 01:23 PM
Finally a HUSKER again
Moparnut426 Offline OP
Have always wondered this,
Is it the wheelbase alone? Will drive shafts interchange?
Re: why is a challenger longer than a cuda [Re: Moparnut426] #1784828
03/21/15 01:43 PM
03/21/15 01:43 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
With identical engine / transmission / rear end combinations, the Barracudas have shorter drive shafts than the Challengers.
Re: why is a challenger longer than a cuda [Re: Alaskan_TA] #1784829
03/21/15 01:44 PM
03/21/15 01:44 PM
With identical engine / transmission / rear end combinations, the Barracudas has shorter drive shafts than the Challengers.
Was there a reason? Seems expensive to me to tool up 2 different Jigs for the E body line up...
Re: why is a challenger longer than a cuda [Re: Moparnut426] #1784830
03/21/15 01:47 PM
03/21/15 01:47 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Back then Dodges always had a longer wheel base than a Ply. Every body style in a Dodge did. I think it went way back to when Plymouth was a cheaper car line.
Re: why is a challenger longer than a cuda [Re: 71birdJ68] #1784831
03/21/15 02:33 PM
03/21/15 02:33 PM
I don't buy this as I know a Roadrunner/Gtx and a Coronet/Superbee are the same. I used a Roadrunner driveshaft in a Coronet before.
Atleast the one I sold the guy was out of a 69 RR and he stuck it in a 69 Bee.....
Re: why is a challenger longer than a cuda [Re: 71birdJ68] #1784832
03/21/15 02:33 PM
03/21/15 02:33 PM
Kirkland, Washington
Pacnorthcuda Offline
Is that true? Very interesting. Even the A bodies?
Re: why is a challenger longer than a cuda [Re: Moparnut426] #1784833
03/21/15 02:36 PM
03/21/15 02:36 PM
I just googled it some and I am seeing 116 wheelbase for the 69 belvedere, road runner, and 117 inches for the coronet, bee. A 1" difference would explain being able to swap a shaft.
Re: why is a challenger longer than a cuda [Re: Pacnorthcuda] #1784834
03/21/15 02:38 PM
03/21/15 02:38 PM
I can see that, but I wouldn't want to put the longer one in the shorter car....
Re: why is a challenger longer than a cuda [Re: Pacnorthcuda] #1784835
03/21/15 03:50 PM
03/21/15 03:50 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Yes, but it is best to keep the u-joint closer to the transmission
Re: why is a challenger longer than a cuda [Re: BSB67] #1784836
03/21/15 04:58 PM
03/21/15 04:58 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
It's true that Dodges traditionally had a longer wheelbase than Plymouths; that goes back to a time when a longer wheelbase was interpreted as "up-market". As was a longer/larger car.
While one can put a shorter-than-optimum driveshaft in a given car, it's hard on the splines and the rear bearing & seal in the trans.
Re: why is a challenger longer than a cuda [Re: topside] #1784837
03/21/15 05:04 PM
03/21/15 05:04 PM
Stay on topic, not about driveshaft lengths!
So are Darts longer than Valiants?
If Dodges are longer across the model lines it does seem that Chrysler went to great lengths (pun intended!) to make this differentiation!
Very interesting...
Re: why is a challenger longer than a cuda [Re: Pacnorthcuda] #1784838
03/21/15 05:06 PM
03/21/15 05:06 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
silly, silly you.....
Re: why is a challenger longer than a cuda [Re: mikemee1331] #1784839
03/21/15 05:12 PM
03/21/15 05:12 PM
Dart...111" wb
Valiant...108" wb
1967-76 darts
1967-73 Valiants
Seems to be a lot of truth to this!
Re: why is a challenger longer than a cuda [Re: Pacnorthcuda] #1784840
03/21/15 05:48 PM
03/21/15 05:48 PM
jersey
Spaceman Spiff Offline
jersey
1958 Plymouth wheelbase is 118 inches
1958 Dodge wheelbase is 122 inches.
My car being a wagon, is on the longer dodge chassis.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: why is a challenger longer than a cuda [Re: Pacnorthcuda] #1784841
03/21/15 06:07 PM
03/21/15 06:07 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
OP Question:
"Will drive shafts interchange?"
Re: why is a challenger longer than a cuda [Re: Pacnorthcuda] #1784842
03/21/15 06:08 PM
03/21/15 06:08 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
Dart...111" wb
Valiant...108" wb
1967-76 darts
1967-73 Valiants
Re: why is a challenger longer than a cuda [Re: Spaceman Spiff] #1784843
03/21/15 06:13 PM
03/21/15 06:13 PM
Pittsburgh, PA
Slotts Offline
Slotts  Offline
Pittsburgh, PA
The difference in the interior between the Cuda and Challenger was cut on the rear leg room of the Cuda. After an hour long drive in the back seat of a Cuda and then riding in the back seat of a Challenger made one think they were in a New Yorker with all the extra 2” of leg room!
Re: why is a challenger longer than a cuda [Re: BSB67] #1784844
03/21/15 06:14 PM
03/21/15 06:14 PM
OP Question:
Yea you're right, my bad.
Re: why is a challenger longer than a cuda [Re: Pacnorthcuda] #1784845
03/21/15 06:51 PM
03/21/15 06:51 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Challenger trunk pan is longer too - a little more room in the Challenger trunk. You can see it.
Re: why is a challenger longer than a cuda [Re: Moparnut426] #1784846
03/21/15 06:54 PM
03/21/15 06:54 PM
San Francisco
dilvoy Offline
dilvoy  Offline
San Francisco
I always thought it for styling reasons to be able to use the curving shape of the main character line on the side of the Challenger and make it graceful.
