Page 4 of 4 1 2 3 4
Re: R block cam Journal question [Re: 1967dartgt] #1782260
03/30/15 04:18 PM
03/30/15 04:18 PM
Glendale Az
Darryls-Demon Offline
Glendale Az
for some reason I seem to remember Callies coming up in the conversation. Maybe I'm wrong.... still confuses the ever lovin s##t out of me
they do they had 8 instock when i got mine ,110 l/c
I have a 112 but would love more.
The cam in my R3 motor is from LSM and it has 115 LSA.
I have no plans on using NOS so I think the motor would be happier with around 110 LSA.
Re: R block cam Journal question [Re: 1967dartgt] #1782261
03/30/15 06:14 PM
03/30/15 06:14 PM
Daytona Beach, FL
cknight Offline
cknight  Offline
Daytona Beach, FL
A 50mm babbit cam bearing usually requires a housing bore of 2.0985/2.0995", Regards, Chase
Re: R block cam Journal question [Re: Leon441] #1782262
03/30/15 08:44 PM
03/30/15 08:44 PM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
Unless they're oddballs, should be a bore size of 2.242" 55mm fit into a 2.480. If I remember correctly.
Re: R block cam Journal question [Re: dodgeboy11] #1782263
03/30/15 10:04 PM
03/30/15 10:04 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
2.135 approximately. Not the most round and don't have block.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: R block cam Journal question [Re: 1967dartgt] #1782264
03/30/15 11:03 PM
03/30/15 11:03 PM
CA.
RAY1969CARS Offline OP
CA.
Apparently the block can't be bored out to a roller using a CNC talk to QMP they can do it it just can't be done with a mandrel type boring needs a 90° Head because of the number five journal is so small And stupid me I have all these race manuals I just looked in the first one and found all the necessary measurements
Re: R block cam Journal question [Re: RAY1969CARS] #1782265
03/31/15 12:58 AM
03/31/15 12:58 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Well..........that changed the way I look at things.
I also thought that all 48 degree blocks used the same cam bearing bore on every journal , but apparently the 48 degree R-1 and some early R blocks used stepped bearings.
I would have thought a mandrel would work too......sounds like it gets involved. Do you need to bore four , then re-set for #5 ?
One more operation and the probable tolerance stacking would have me thinking long and hard.
Page 4 of 4 1 2 3 4
