Re: Big Block Mopar coolant flow direction
[Re: GLR]
#1778559
03/13/15 12:53 PM
03/13/15 12:53 PM
RapidRobert
pump draws coolant in from the lower hose and pump it into the lower (bottom) block holes on each side. heated coolant comes out of the upper (2) block holes & each passage turns in/joins at the center stat housing/out to top hose
[Re: 451Mopar]
#1778562
03/14/15 11:37 AM
03/14/15 11:37 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Reverse flow pumps flow into the heads and it comes out the block. Theory behind it is the heads need cooling more than the block. I just don't know how they push and pull from the radiator. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: astjp2]
#1778563
03/14/15 03:26 PM
03/14/15 03:26 PM
Posts: 18,157 Mass
DAYCLONA
Mass
The antiquated stock "Mopar" cooling system (based on Ford's model T) leaves a lot to be desired, a serpentine belt drive that "reverses" the pump, thus the coolant flow as described above is THE preferred cooling for the standard American V8, Sorry Guys but GM knew and implemented this decades ago, everyone else just followed along years later
If anyone is contemplating a reverse flow belt drive on an antiquated cooling system, BB or SB, just make sure the water pump impeller is a straight vane design, a crossflow radiator makes a world of difference, and depending on the application, make sure the thermostat is in the correct flow position
[Re: beatgoeson]
#1778565
03/14/15 10:43 PM
03/14/15 10:43 PM
RapidRobert
For a good read on the subject (of cooling) you might go to www.moparchat.com then scroll down & click on "circle track chat" & read Sanborns cooling mods that are in a sticky at the top of the page (it'll take you an hour to absorb the jist of it). He's one of the countries' foremost SB cooling mod experts & alot can be adapted to a BB (BB just has some different routing in the front mainly). If you need tips on drilling Felpro blue head gaskets WO tearing em up just holler, I'll save you some grief (& time/cash)
