70 cuda shaker #1778490
03/13/15 10:25 AM
03/13/15 10:25 AM
Wisconsin
71duster414 Offline OP
Wisconsin
Does anybody know where I can get original pictures of the assembly of a shaker, from base plate, air doors and cable all the way up to bubble install? I want to see the correct way everything should look.
Brent
hoffmanhhr@gmail.com
Re: 70 cuda shaker [Re: 71duster414] #1778491
03/13/15 10:47 AM
03/13/15 10:47 AM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
Re: 70 cuda shaker [Re: shakerjoe] #1778492
03/13/15 11:47 AM
03/13/15 11:47 AM
Wisconsin
Wisconsin
Thanks, I'm still uncertain where or how the warm air door mounts/ fastens to?
Re: 70 cuda shaker [Re: 71duster414] #1778493
03/13/15 01:00 PM
03/13/15 01:00 PM
Kennewick, Wa.
71vert340 Offline
71vert340  Offline
Kennewick, Wa.
Underside of scoop. See pic
Re: 70 cuda shaker [Re: 71vert340] #1778494
03/13/15 01:12 PM
03/13/15 01:12 PM
Kennewick, Wa.
71vert340 Offline
71vert340  Offline
Kennewick, Wa.
Opened up.
Re: 70 cuda shaker [Re: 71vert340] #1778495
03/13/15 01:20 PM
03/13/15 01:20 PM
Kennewick, Wa.
71vert340 Offline
71vert340  Offline
Kennewick, Wa.
I've seen that assembly drawing several times but I just noticed it doesn't appear to show the copper ground strap or the short ground bar to the baseplate.. Interesting.
Terry
Re: 70 cuda shaker [Re: 71vert340] #1778496
03/13/15 04:17 PM
03/13/15 04:17 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
I believe where it says "clip", showing two pieces is the reference to the ground straps...pretty poor desription
Re: 70 cuda shaker [Re: mccannix] #1778497
03/13/15 09:19 PM
03/13/15 09:19 PM
Wisconsin
Wisconsin
Thank you!
Re: 70 cuda shaker [Re: mccannix] #1778498
03/14/15 06:42 PM
03/14/15 06:42 PM
Kennewick, Wa.
71vert340 Offline
71vert340  Offline
Kennewick, Wa.
One clip attaches the rod to the warm air door. I see the other two clips on that drawing, but you're correct, a weird description. Thanks.
Terry
Re: 70 cuda shaker [Re: 71vert340] #1778499
03/14/15 07:56 PM
03/14/15 07:56 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
There are 2 clips, one on each end of the rod that holds the two doors together.
Although a poor description, I think in the diagram it was meant for 'clip' to be interpreted as the two ground straps.
