Re: What vehicle and what year to find a 518 tranny??
[Re: Diego_Ted]
#17784
10/20/05 10:46 AM
10/20/05 10:46 AM
Posts: 8,094 Sunnyvale, CA
Jeepmon
Sunnyvale, CA
518 trannys are very common in the Dodge Ram trucks.. The older ones used the 47RH (hydraulic) and the newer ones use the 47RE (electonic)... Check out this place for all information on 518's 518 Trannys
[Re: Diego_Ted]
#17787
10/20/05 01:37 PM
10/20/05 01:37 PM
I got mine thru www.car-part.com Its a great site and easy to use basically connects you with every junk yard in the country. depending on what you plan to use your car for, a non lockup unit may be better. you can use a 727 converter which are widely available. lockup converters (performance) are scarce and expensive.
#17788
10/20/05 06:08 PM
10/20/05 06:08 PM
Posts: 2,111 Bowie, MD
Reggie
Bowie, MD
IIRC, the '95 and earlier versions are the ones to look for because they are easy to wire.
The non-lockup units will have two pins (contacts) towards the back of the main case just ahead of the rear oil line port. It needs one fuse protected hot wire and one switch controlled ground wire to control OD. Mine came from a 91 Ram 5.9 Reading-bodied work truck.
The lockup units will have three pins towards the back of the main case just ahead of the rear oil line port. It needs one fuse protected hot wire, one switch controlled ground wire to control OD and one switch controlled ground wire for LU.
I think after '96, the 518s are controlled by electronics and would be hard to adapt to an older car.
[Re: uwntsumrtII]
#17790
10/21/05 04:11 PM
10/21/05 04:11 PM
If the plan was to cut the bellhousing off and install a JW bellhousing, would it make sense to get a trans from a diesel ?
#17791
10/21/05 05:06 PM
10/21/05 05:06 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
high stall torque converters are the issue with a diesel trans....IIRC a gas tc won't interchange with a diesel TC...
also, for a 518, '91-92 were non lockup, IIRC, 93-9? are the hydraulically controlled (the cutoff seems kinda unsure, could be as early as 96 (when OBDII came on the trucks) or as late as '98 (when the trucks were freshened)
[Re: patrick]
#17792
10/21/05 05:15 PM
10/21/05 05:15 PM
Aside from the converter- I could have a custom one built- would the diesel trans be a better core ? More HD parts i would think ? Remember, I'll be changing the bellhousing no matter what, it's going on a big block.
[Re: patrick]
#17793
10/21/05 06:02 PM
10/21/05 06:02 PM
Posts: 25,949 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The diesel transmissions have the same input shaft and drive hub as the gas versions so, once the bellhousing is hacked off for an Ultrabell, a diesel trans will work as well as any other.
