Re: differences between dart and dart gts?
[Re: Adam71Charger]
#1777923
03/12/15 05:26 PM
03/12/15 05:26 PM
Posts: 7,371 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
Lots of good info here. http://www.hamtramck-historical.com/library-2.shtmlBasically the GTS was the performance model. The GT gave you some of the sporty GTS equipment without the larger engines. You couldn't get the 340 or 383 in a Sedan, 270 or GT. The interior/exterior trim were specific to the model.(trim and engine options varied by year)
[Re: Cab_Burge]
#1777927
03/12/15 08:03 PM
03/12/15 08:03 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
In '67, the GTS was introduced in very low numbers. It was only available with the 383, and they are rarely seen now. In 68 the 340 was introduced to the GTS as the base engine. In '69 began the Swinger 340, with the 340 as the only engine option. Swinger 340 carried over to 1970, but the GTS and factory big block A bodies were history.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: mopar346]
#1777929
03/14/15 12:35 AM
03/14/15 12:35 AM
Posts: 27,471 So Cal
autoxcuda
So Cal
Early 69 had GTSs, mid year (not exactly sure of the date change over) it went to Swingers. GTS standard with buckets (bench was an option), Swinger standard with bench (I believe not bucket or console option).
No.
The GTS and Swinger were separate models and were offered simultaneously throughout the whole 1969 model year.
Just like Road Runner's being offered simultaneously with GTX's.
[Re: mopar346]
#1777931
03/14/15 01:43 PM
03/14/15 01:43 PM
Posts: 43,603 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
From 1967-1969 all GT and GTS's were 2-door hardtops. 457 383 GTS's were built in 1967. In 1968 the 340 became available for the GTS. In 1969 the 440 became available, 640 made. The GT and GTS shared many trim parts, but the GTS had no side moulding therefor no holes though the sheetmetal was the same, you have to weld or bondo the moulding holes to make it look like a GTS. The 1969 340 Swinger shared the GTS sheetmetal with no trim holes, but had the low-line dash trim and bench seats, and rubber floor coverings were standard, carpet was extra. Late in the 69 model year you could order buckets, but very few were built that way.
JB Rhinehart, Realist
A-Body's RULE!
[Re: mopar346]
#1777932
03/14/15 02:12 PM
03/14/15 02:12 PM
autoxcuda
So Cal
No.
The GTS and Swinger were separate models and were offered simultaneously throughout the whole 1969 model year. Just like Road Runner's being offered simultaneously with GTX's.
I know they are 2 different models but I didn't think they ran together like the GTS and Swinger. I thought, maybe incorrectly that the GTSs were built early 69 and then they switched to the Swinger, is this incorrect? Did they run GTS & Swingers at the same time? I do recognize the upscale nature of a GTS in relations to a Swinger but never associated them to RR/GTX but it's a good comparison.
They ran GTS's and Swingers at the same time.
[Re: Cab_Burge]
#1777933
03/14/15 02:45 PM
03/14/15 02:45 PM
Posts: 18,678 Fresno, CA
Jim_Lusk
Fresno, CA
I'm almost sure that the GTS option, along with the Swinger option, didn't come out until 1968
Nope. GTS in 1967 and Swinger in 1969.
