Since the new motor went in I have noticed some slippage out of my 727 so I've decided to rebuild a core that I had in corner of the garage for a few years. The core is a 71 unit from a std performance 440 car. The first step was easy, taking the trans apart. We will soon find out if it will go together as easy as it came apart.
I started out by bagging and labeling all of the small parts. Next was a trip the the hot tank.
All of the boars were checked for ware and scoring, then honed with a crossbuff.
The pointer in this shot points to a 1/8th hole I drilled into the return line channel to feed additional oil to the sprag.
stay tuned for part 2
