1969 Hemi brake booster OR no Hemi brake booster? #1777599
03/12/15 01:02 AM
03/12/15 01:02 AM
Rapid City, South Dakota
six-pack-mopar Offline OP
Looking for some good expert thoughts on a 69 Hemi Roadrunner that we are restoring. What Bendix master cylinder was used on a front drum brake car? I have seen pictures where these cars did NOT use the booster and offset bracket. Secondly, where we can see a brake booster and offset bracket, What Bendix master cylinder was used on this application? I guess this would be with front disc brakes?
I've been told that ALL Hemi Roadrunners used the booster and disc brakes but I've seen cars with only a master cylinder w/o the booster. I guessing these were front drum brake cars?
What is correct? Maybe some original car owners car to chime in.
Thanks for your thought.
Buddy
Re: 1969 Hemi brake booster OR no Hemi brake booster? [Re: six-pack-mopar] #1777600
03/12/15 04:15 PM
03/12/15 04:15 PM
Jefferson State
srt Online content
ESYC
srt  Online Content
ESYC
Jefferson State
off the top of my head 69 was std with drum all around (11x3 front 11x2.25 rear iirc) first option would be power drum and finally power disc.
I'm absolutely NOT sure about the master cyl's yet believe there are two different ones 1 for manual drum, the other for power drum or disc.
Re: 1969 Hemi brake booster OR no Hemi brake booster? [Re: srt] #1777601
03/12/15 07:22 PM
03/12/15 07:22 PM
Innisfil Ontario Canada
Mogre Offline
Mogre  Offline
The Ram Man will have the answer to some of your questions. A friend just got the hemi booster and master cylinder from him. Great guy to talk to and very knowlegable. Google " Ram Man "
Re: 1969 Hemi brake booster OR no Hemi brake booster? [Re: six-pack-mopar] #1777602
03/12/15 07:49 PM
03/12/15 07:49 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Buddy
A 69 HEMI Road Runner could be equipped with either manual 4 whl drum brakes or power discs that used the offset dual diaphram Bendix Booster....your "restoring" a HEMI Road Runner, what was it equipped with?, or are you looking to "upgrade" the brake package?
Mike
Re: 1969 Hemi brake booster OR no Hemi brake booster? [Re: six-pack-mopar] #1777603
03/14/15 04:52 PM
03/14/15 04:52 PM
Niwot, CO Formerly denn...
dynorad Offline
dynorad  Offline
I believe the offset is needed for valve cover clearance and for spark plug replacement.
The 4 speed cars cam with power discs standard. Not sure what the options were for drum cars.
Re: 1969 Hemi brake booster OR no Hemi brake booster? [Re: dynorad] #1777604
03/14/15 10:09 PM
03/14/15 10:09 PM
Valley of the sun, AZ
2
2JcodeChargers Offline
Transmission choice makes no difference on the brake package. The axle option does. If the car was ordered with the A34 Super Track Pak 4:10 dana then it had power disks std. A 4 speed ordered with the A33 axle could have manual drums. That's the way my original 69 Hemi Charger 500 is equipped. 4 speed with manual drums.
Re: 1969 Hemi brake booster OR no Hemi brake booster? [Re: six-pack-mopar] #1777605
03/14/15 10:58 PM
03/14/15 10:58 PM
Tennessee
Hemi ragtop Offline
Hemi ragtop  Offline
Tennessee
What ever you do, if you use power brakes, use the stock type Bendix booster and mounts. I enabels you to remove the booster to adjust valves etc., without having to remove break lines. I bought mine from the Ram Man after first trying a "chevy" copy that didn't work. Expensive but it is not only correct, it works.
Re: 1969 Hemi brake booster OR no Hemi brake booster? [Re: Hemi ragtop] #1777606
03/16/15 01:57 AM
03/16/15 01:57 AM
Thanks everybody for your thoughts which all help. Also thanks to Brad with user name mastershake340 who really knows his stuff on master cylinders. All have been a big help.
Buddy
