Re: Anyone run a Pertronix Ignitor3 billet distributor?
[Re: ProSport]
#1777218
03/14/15 02:24 PM
03/14/15 02:24 PM
Posts: 12,132 Cleveland
sunroofgtx
Cleveland
Sorry, Bob. It's not ready yet. Maybe by the winter. Our 6AL type Ignition Box has the rev-limiter, but there is wiring.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
[Re: sunroofgtx]
#1777219
03/14/15 03:44 PM
03/14/15 03:44 PM
Posts: 760 Canada
CTD5.9
Canada
Do you have the ignition box on your website? I am looking for one and after installing your ready to run on an engine this morning I would find it hard not to buy an ignition box
[Re: CTD5.9]
#1777220
03/14/15 06:18 PM
03/14/15 06:18 PM
Posts: 277 MN
Willie68coronet
MN
Mancini has them. firecore 6 series
'68 Coronet 500 w/ Indy EZ-1 headed 446, 727 trans, 9" rear First day at the track with SUV street tires and no traction: 1.688 60', 7.24 @ 101.79 in the 1/8 mile
Great customer service from: DominicThumper Carbs, B3 racing engines, Porter Racing Engines, A-1 torque converter's, Quick Performance, Racer Brown Cams, R&R Performance, Manton pushrods
[Re: max_maniac]
#1777224
03/18/15 11:53 AM
03/18/15 11:53 AM
Posts: 17,928 Akron, Ohio
ProSport
Akron, Ohio
Look at it this way Bob ------ LESS weight
Russ
Hadn't thought of it that way yet!
[Re: ProSport]
#1777227
03/23/15 11:34 PM
03/23/15 11:34 PM
Posts: 60 IN
Matt Erich
IN
Did you get the 400 Dist or order the 440 and cut the shaft?
Owner of Custom33.com 1933 Plymouth Coupe and Roadster Kits
[Re: Matt Erich]
#1777228
03/24/15 12:06 PM
03/24/15 12:06 PM
ProSport
Akron, Ohio
400 Distributor.
It is up and running, I really like the easy access to the advance Springs, right under the rotor. The Rev limiter I need to play around with, the tiny adjuster seems to jump all over the place rpm wise, and it seemed to kick in early. I will get it figured out and I might just buy their external Rev limiter box as it would be easier to set and to do quick low rpm settings just to make sure the Rev limiter is working.
