Oil level question
#1776873
03/11/15 03:43 AM
03/11/15 03:43 AM
Posts: 733 jacksonville,FLORIDA
slammedR/T
This is kind of a dumb question but gonna ask it anyway. I have a moroso drag race rear sump oil p/n 20732, according to moroso it is a 7qt. oil pan. Now this would mena that I could put 7 qts. in my oil pan, and this is where the full mark should be on the dip stick correct? I am using my stock oil dipstick for my 2000 dodge dakota, with 7qts. in the pan it is reading WAY! over filled. I'm thinking I should fill the pan with 6qts. and make a new mark on my dipstick for my oil level. I read in an older thread that Brian Hafliger said to run this pan about 1-1.5qts low for best performance.
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
Re: Oil level question
[Re: slammedR/T]
#1776874
03/11/15 10:23 AM
03/11/15 10:23 AM
Posts: 13,417 Marion, South Carolina [><]
an8sec70cuda
Best thing would be to call Moroso and ask if it's 7 quarts in the pan only or if it's 7 quarts w/ the filter. Sometimes the pan manufacturers aren't very clear on that.
[Re: an8sec70cuda]
#1776878
03/11/15 06:05 PM
03/11/15 06:05 PM
slammedR/T
I will do this, it says in the catalog it is a 7qt. capacity oil pan but doesn't say if with or without oil filter added into capacity figure??
That why I fgured I would fill it to 6qts. and remark my dipstick.
[Re: slammedR/T]
#1776879
03/11/15 06:14 PM
03/11/15 06:14 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I built the pan for my 416.. its a 10 qt pan and I use the short oil filter... I run it 1 qt low in the pan to keep the oil away from the crank ![](/ubbthreads/images/graemlins/wave.gif)
