Page 2 of 3 1 2 3
Re: My 337 MW intake.... [Re: sixpackgut] #1774992
03/11/15 12:47 PM
03/11/15 12:47 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
before
Re: My 337 MW intake.... [Re: sixpackgut] #1774993
03/11/15 01:01 PM
03/11/15 01:01 PM
an8sec70cuda Offline
Check your private messages Ray.
CHIP
'69 road runner, 440-6, 4 speed, Dana 60
'71 Demon 340, no drivetrain, on blocks behind the barn
'06 GMC 2500HD LBZ Duramax
Re: My 337 MW intake.... [Re: sixpackgut] #1774994
03/11/15 01:05 PM
03/11/15 01:05 PM
Weddington, N.C.
Streetwize Offline OP
Weddington, N.C.
Sport,
Thanks for the kind words.
the 517 has 11.8:1 (IIRC) and a Bullet 264/268@.050 Hydraulic roller, it revs safely to 6800-7000, it's the only motor I've ever needed the shift light for it gets there really quick, especially for a big block.
Going to 4.10's and an aluminum flywheel 4 speed (what the car originally came with).
Chip, I'm sure porting is all dependent on the type of manifold (ex: Tunnel ram vs a 1 4BBL) and the level of work involved.
Do you know Hollis at HP, Chip? If not I'd really suggest you meet him and Larry, I introduced Stephen Daurity to him back around the Holidays, Absolutely GREAT Mopar people to work with.
www.hpengines.net check out his Facebook page he's got some pics of Larry's work, I know they just finished a 5.0 Coyote motor and the heads looked AMAZING
WIZE
In Car:
Re: My 337 MW intake.... [Re: Streetwize] #1774995
03/11/15 04:15 PM
03/11/15 04:15 PM
No, I don't know them. I've had good luck w/ a local shop here (Jordan's Performance in Conway) since I stopped doing my own machine work.
I was just curious what they charged to do your manifold...I'm sure mine would probably be more. It has a lot of material to work with.
CHIP
Re: My 337 MW intake.... [Re: an8sec70cuda] #1774996
03/12/15 01:31 PM
03/12/15 01:31 PM
Norwood NC
HP Engines Offline
HP Engines  Offline
Norwood NC
Depending upon floor architect of the plenum,
on the crossram,
Larry may have some pointers to help with
Puddle. Whether it be grinding, reshaping,or
perhaps epoxy depending on fuel type used.
Plastic bolts on the lid is good insurance too.
Btw, streetwize your intake looks great!
Re: My 337 MW intake.... [Re: HP Engines] #1774997
03/12/15 01:53 PM
03/12/15 01:53 PM
on the crossram,
Well hey Hollis! Heard a lot of good things about your shop!
My Barton hemi manifold is not the crossram...I have the single 4500 manifold.
CHIP
Re: My 337 MW intake.... [Re: an8sec70cuda] #1774998
03/12/15 01:59 PM
03/12/15 01:59 PM
dogdays Offline
dogdays  Offline
The plastic bolts idea is really good, thanks for that.
R.
Re: My 337 MW intake.... [Re: dogdays] #1774999
03/12/15 05:41 PM
03/12/15 05:41 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Awesome idea! Have you used any specific type?
Re: My 337 MW intake.... [Re: ScottSmith_Harms] #1775000
03/16/15 11:40 AM
03/16/15 11:40 AM
Weddington, N.C.
Weddington, N.C.
I haven't picked it up yet but here's a pic Hollis sent me of Mr LarrySmith's 337 Porting
WIZE
In Car:
Re: My 337 MW intake.... [Re: Streetwize] #1775001
03/16/15 12:21 PM
03/16/15 12:21 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
that is extremely nice work
Re: My 337 MW intake.... [Re: an8sec70cuda] #1775002
03/16/15 12:44 PM
03/16/15 12:44 PM
Benton, IL.
DaveRS23 Offline
Master of nothing...
DaveRS23  Offline
Benton, IL.
on the crossram,
I have the Barton single too, and have thought about having it cleaned up. But everything is so hush-hush. I would just like to know how much improvement can be had and how much it would cost. But I just never see that info. With it, it would be a simple decision.
If you get it done, if you would share the bottom line, I would appreciate it. If there is enough to be gained to justify the cost, I would like to have mine done, too.
Master, again and still
Re: My 337 MW intake.... [Re: Streetwize] #1775003
03/16/15 01:15 PM
03/16/15 01:15 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Oh, can I play "post a picture of a ported intake plenum", too?
Here's an older pic into the heart of my Franken-intake RB M1 4150.
Re: My 337 MW intake.... [Re: BradH] #1775004
03/16/15 04:02 PM
03/16/15 04:02 PM
Weddington, N.C.
Weddington, N.C.
On a Street Dominator (similar to the M1) I always make the #1 and #7 roof a slightly taller Trapezoid (Gumby's head, I call it) than the port next to it in the plenum (in this case #2 and #5 respectively) that pulses before it. It seems to work really well judging from before/after plug readings where #1 and 7 were a little lean.
In a single plane with adjacent firing holes the first fed tends to be the best fed on many Siamese port heads and intakes. An old NASCAR guy taught me this many moons ago.
I used to have some shots of my SD mods (in rough, unfinished form) that illustrate it but I think I conveyed the Gist of it.
WIZE
In Car:
Re: My 337 MW intake.... [Re: Streetwize] #1775005
03/23/15 11:32 AM
03/23/15 11:32 AM
Weddington, N.C.
Weddington, N.C.
More Pics
WIZE
In Car:
Re: My 337 MW intake.... [Re: Streetwize] #1775006
03/23/15 11:32 AM
03/23/15 11:32 AM
Weddington, N.C.
Weddington, N.C.
the other side (tough to tell)
WIZE
In Car:
Re: My 337 MW intake.... [Re: Streetwize] #1775007
03/23/15 11:33 AM
03/23/15 11:33 AM
Weddington, N.C.
Weddington, N.C.
side of plenum, roof radius work
WIZE
In Car:
Re: My 337 MW intake.... [Re: Streetwize] #1775008
03/23/15 11:40 AM
03/23/15 11:40 AM
Weddington, N.C.
Weddington, N.C.
Last one, pics don't do it justice
WIZE
In Car:
Re: My 337 MW intake.... [Re: Streetwize] #1775009
03/23/15 01:16 PM
03/23/15 01:16 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
Nice work!!
2 kids and a dog
Re: My 337 MW intake.... [Re: TonyS451] #1775010
03/23/15 07:26 PM
03/23/15 07:26 PM
Weddington, N.C.
Weddington, N.C.
I think I'll be bringing Mr Larry some more stuff to whittle on Purdy soon, very happy with the quality of the porting work, it's a shame to cover it up with a carburetor now
WIZE
In Car:
Re: My 337 MW intake.... [Re: Streetwize] #1775011
03/25/15 02:38 PM
03/25/15 02:38 PM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
That looks awesome Bobby
I'm anxious to hear how the stroker likes that manifold.
Fwiw mine was installed straight out of the box and wasn't even port matched to the EZ 295's. Compared to the taller ICH 440-2 it was only down 10hp on the dyno in back to back tests. I'm sure your's is every bit as good as the ICH piece if not better
AndyF stated in the past that the 337 and Super Victor were identical on his dyno mule making in the 800HP range.
You can't beat the 337 for those of us who are clearance challenged wanting to run a stock hood.
Ron
Page 2 of 3 1 2 3
