Re: 1968 DART GTS Question? Inland shifter?
[Re: mccannix]
#1773850
03/07/15 02:22 AM
03/07/15 02:22 AM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
Looks like T7 on the tag which is the tach code. As for the Inland, I think the rule is if there is a reverse light on the dash it was a Hurst car, I don't see the light so it appears to be an Inland car.
Hurst appeared later in the production run, maybe Feb or so, at least on B-bodies, it appears to be a 929 build date so ealry, again pointing to an Inland car.
Careful, your character's showing!
[Re: mopar346]
#1773852
03/07/15 02:44 AM
03/07/15 02:44 AM
Posts: 17,547 Las Vegas, NV
6bblgt
Las Vegas, NV
I think everyones got it covered! Although I'm not so sure about the HURST shifted cars not having a "REVERSE" light? 340 4-spd GTS - yellow w/black top, interior, stripes Is it an early LA car LS23P8 E10xxxx?
[Re: 6bblgt]
#1773854
03/07/15 04:02 AM
03/07/15 04:02 AM
Posts: 27,555 So Cal
autoxcuda
So Cal
340 4-spd GTS - yellow w/black top, interior, stripes Is it an early LA car LS23P8E10xxxx?
Have to check that number: 109334
Troy has 68 model year 340 from the Los Angeles plant (67 cast date). He just finished rebuilding the long block along with X heads, going to put it on a run stand, and then sell it.
[Re: rarefish]
#1773864
03/07/15 04:41 PM
03/07/15 04:41 PM
Posts: 4,333 Prospect, PA
BSB67
Prospect, PA
The big question has been, on what date did the factory switch from the Inland shifter to the Hurst shifter for the 1968 model year?
Actually, I believe the big question was whether an inland came in 68's or not. Was answered yes. Several questions followed, including about the reverse light.
