Page 2 of 3 1 2 3
Re: HP per cubes... [Re: dvw] #1772144
03/06/15 12:06 AM
03/06/15 12:06 AM
gregsdart Offline
gregsdart  Offline
I think my package is pretty average to good for a bracket medium cost build. Best pass on big heavy 15x33.6 stiff sidewall slicks is 8.80 at 151 mph, 3050 lbs, 1600 DA. My guess is that it is an honest 875 hp if you want to talk numbers. Ported 440-1 heads, 528 cubes, 15/1 compression, mega block, 3x intake, terminator on alky, .775 lift on the intakes, and shifting at 7100 rpm. If I had gone Tunnelram and Hat, I have been told by more than one very respected engine builder it would pick up about 35 hp. That would make it run about .08 quicker. I'm sure if I flogged the daylights out of it I could find a few more hp, so I don't see 900 hp as unattainable.
As has been pointed out, we are racing a dinosaur, running a BB. I bought STOCK gen 3 hemi heads that out flow my 440-1 ported heads up to .600 lift, and ported will kick butt and flow 400 + cfm. But again the Mopar camp is behind the eightball, on valvetrain stuff for starters.
Re: HP per cubes... [Re: gregsdart] #1772145
03/06/15 12:22 AM
03/06/15 12:22 AM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Thanks all... I think I understand now..
Re: HP per cubes... [Re: Jeepmon] #1772146
03/06/15 12:31 AM
03/06/15 12:31 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I don't know really...I went for max cubes....Drivability, earth shattering torque, and hopefully light weight.
Re: HP per cubes... [Re: Jeepmon] #1772147
03/06/15 01:10 AM
03/06/15 01:10 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
I got right at 2hp/inch NA with 9:1 CR. Pretty happy with that
Re: HP per cubes... [Re: Dragula] #1772148
03/06/15 01:14 AM
03/06/15 01:14 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I love the max cubes, my heads flow 386@.700 and I've only got 10.4-1 compression. But talk torque, at 3500rpm (the start of the pull)764ftlbs. It's at 800 before 4100, peaks at 818.4@4818 and doesn't drop below 800 until after 5500rpm.
You should eclipse this numbers in spades.Dave
Re: HP per cubes... [Re: SpareParts] #1772149
03/06/15 01:41 AM
03/06/15 01:41 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
. With what power adder
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: HP per cubes... [Re: WHITEDART] #1772150
03/06/15 01:48 AM
03/06/15 01:48 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Umm gasoline
Re: HP per cubes... [Re: SpareParts] #1772151
03/06/15 01:58 AM
03/06/15 01:58 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Umm gasoline
. Tell us details et/cubic inches/weight I believe you just curious
Re: HP per cubes... [Re: WHITEDART] #1772152
03/06/15 02:36 AM
03/06/15 02:36 AM
Down under
O
OUTLAW565 Offline
OUTLAW565  Offline
O
Down under
I got 2.28 hp per ci. 11.9 to 1 cr.
Re: HP per cubes... [Re: Jeepmon] #1772153
03/06/15 02:46 AM
03/06/15 02:46 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
If you're building a n/a race motor.. what horsepower per cubic inch would you be happy with?
Me personally, I think 1.5 per cube is a dissapointment....
Thanks, my hemi is a dissapointment and so was my last big block.
Every engine, my van wont open a 4bbl
Re: HP per cubes... [Re: WHITEDART] #1772154
03/06/15 02:49 AM
03/06/15 02:49 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
I wasn't looking for an argument (just so this doesn't come across as rude) I'll share very little as I only run the car clocks off. It's a 360" R3, W heads, cast intake. Never been on a dyno but according to a time slip and equations it makes 2.X per cube. Next it goes into a heavier stock suspension car and will see some nitrous
Re: HP per cubes... [Re: SpareParts] #1772155
03/06/15 03:43 AM
03/06/15 03:43 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Easily believable, even with low compression.........Small cube, good head.
Re: HP per cubes... [Re: Monte_Smith] #1772156
03/06/15 03:53 AM
03/06/15 03:53 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Well I certainly don't like to lie to the Mopar crowd, maybe it'll make another person wanna go "fast" not that I'm the baddest dude ever but around me I can only think of two grudge raced mopars I think would kill me.
Monte what's the best way to contact you? I have some questions about my big shot plate and would love to order a shirt or hoodie or something. Thanks!
Re: HP per cubes... [Re: Jeepmon] #1772157
03/06/15 04:15 AM
03/06/15 04:15 AM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
The engine in my Demon makes somewhere near 1.6 HP per cube. 418 c.i. SBM with production cast iron heads and a .590 lift Racer Brown flat tappet camshaft. 1875 passes and counting. Pistons or crankshaft never out of the block since day one. 3050# and 9.69 at 136 mph 1/4 mile and 6.09 at 111 mph 1/8th mile.
Whats amazing is the engine in my Lebaron makes almost exactly the same HP per C.I. at 1.61 HP per cube. The only thing common between the two is the same grind camshaft. The Lebaron is 512 c.i. BBM with Indy SR heads. The Lebaron has been 5.45 at 126 1/8th mile and 8.58 at 156 1/4 mile. weighs 2560 lbs. I shift at 7000RPM in both cars.
About $11K in the BB and only $6K in the SB
Re: HP per cubes... [Re: qwkmopardan] #1772158
03/06/15 09:49 AM
03/06/15 09:49 AM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Not trying to make you mad but i calculate your SB at 1.46, my hemi 1.42
And your BB at 1.51, slightly better than my BB. Hopefully, Im a loser and calculating something wrong so Jeepmon wont be dissapointed in my engines
Re: HP per cubes... [Re: Jeepmon] #1772159
03/06/15 11:04 AM
03/06/15 11:04 AM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
The level of dedication all of you put into building all this power NA is astounding and admirable. While I can appreciate it, I also know that I myself am lazy to a large degree, and NOT that dedicated. I want more power but don't want to work that hard for it. I drive my junk on the street mainly, so torque is king.
I know what the last dyno chart showed, but in the chassis is all that matters.
4200# to 133.65 mph in a low-rpm, mild-mannered street 360.
I'd be nowhere without my turbo.
Re: HP per cubes... [Re: sixpackgut] #1772160
03/06/15 01:31 PM
03/06/15 01:31 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
I guess the big question here is.. Are you disappointed ?? I'm trying to figure what or where the benchmark should be.. Should 1.2 to 1 be considered disappointing? how about 1.6 to 1?
and if so.. does than mean that 2 to 1 is outstanding?
Re: HP per cubes... [Re: Jeepmon] #1772161
03/06/15 01:44 PM
03/06/15 01:44 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
I really never once put HP per cube in my thought process. When I decided to put a hemi in my cuda I figured it would make around 600hp without much effort and Get me a 10.00 car. it did that so I wasn't disappointed.
Re: HP per cubes... [Re: sixpackgut] #1772162
03/06/15 02:07 PM
03/06/15 02:07 PM
Renton Washington
Triple Threat Offline
Renton Washington
My stuff only makes about 1.35 per cube, which isn't much. But I knew that going in, and reliability is more important to me that wringing more HP out of it.
I'm a head swap away from being at 1.6 per cube. But it hasn't happened yet.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: HP per cubes... [Re: Jeepmon] #1772163
03/06/15 03:38 PM
03/06/15 03:38 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
It seems everytime I sit down with an engine builder, the one stat they keep throwing out is HP vs Inches.
You can see it right there - it's tremendously subjective - by builder. As a customer you need to find a builder that you identify with, so you're on the same page interms of the $$ per HP per cid. Most of my stuff is street first, occasional race second, and in the 1.2-1.3 range. If a bracket race engine was the goal, I would think a similar result, maybe a little more for something that needs oil changes and jetting adjustments over a season or two. A full race effort, top dollar parts, all the goodies, and big inch I'd expect to see higher than 1.7.
The heads are still part of the whole equasion. A big part, but not all of it. Wonder how Stock Eliminators make 1.4hp/inch with limited heads, carbs, and cams? Ring seal, camshaft selection, exhaust manifolding, & the knowledge base to know and use the tricks...
To reach 1.8-2.0 per inch everything has to be perfect, and stay perfect. and as you get bigger that all costs more.
Page 2 of 3 1 2 3
