340 shift points
#1771883
03/05/15 02:06 AM
03/05/15 02:06 AM
Posts: 3,518 pacific northwest
Stroker Scamp
pacific northwest
Have a 340, 750 Holley DP carb, performer manifold. 1 5/8 headers, unknown compression and I believe a stock bottom end, has a hyd cam in it but unknown So I am going to take it to the track and see what it has. I have had it up to 5500 at shifting. What would be a safe RPM not to exceed?
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
Re: 340 shift points
[Re: Stroker Scamp]
#1771884
03/05/15 02:11 AM
03/05/15 02:11 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Thats a unknown.. but I would think 6000 is easy IF you have any kind of decent valve springs... I use to go higher than 6000 on a stock engine... valve springs were the weak point ![](/ubbthreads/images/graemlins/wave.gif)
[Re: ademon]
#1771887
03/05/15 10:10 AM
03/05/15 10:10 AM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Put you big boy pants on. Turn it til it pukes. Fix it and drop a hundred off the rpm. LOL
[Re: Leon441]
#1771888
03/05/15 11:31 AM
03/05/15 11:31 AM
Posts: 20,698 in a cattle trailer down by th...
Guitar Jones
![](/ubbthreads/images/graemlins/haha.gif)
I used to twist my 340 to 8500 but it was far from stock. ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: Stroker Scamp]
#1771890
03/05/15 06:11 PM
03/05/15 06:11 PM
Posts: 26,032 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I've always thought the pushrod angle is the limiting factor in the LA engine rev limit.
[Re: John_Kunkel]
#1771891
03/05/15 09:24 PM
03/05/15 09:24 PM
Triple Threat
Renton Washington
Mike my old 340 was stock bottom end, Eddy heads, 230/230 480/480 hyd cam, air gap, 750.
5600 was the sweet spot, it didn't go any faster spinning it higher.
[Re: Stroker Scamp]
#1771893
03/06/15 07:58 AM
03/06/15 07:58 AM
Posts: 608 TN
1DGEMAN
TN
Back in the old days of Stock Elim when you had to run stock springs and stamped rockers and real factory cam. I shifted at 6800 in both hc and lc 340's at 7200 it would punch rockers. I had first hc and lc 340's to hold NHRA national records in the 11's. Many years later had 1st lc 340 record holder in the 10's shifted that at 7800. 340's like rpm. Modern cams should work a lot better than the old stock cam. I would start at 6500 and go up from there. Let your ET slip be your guide.
Real Men shift for themselves
[Re: Cab_Burge]
#1771895
03/10/15 11:23 PM
03/10/15 11:23 PM
Stroker Scamp
pacific northwest
Well didn't get to drive the car, the Wife did and it was her first time down the track. I told her just put it in drive and punch it. So with hard as rock Toyo's spinning in first and the car shifting on its own ran a 13.85 @ 96 mph Nothing broke and we drove it back home and I think she is hooked. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Leon441]
#1771896
03/10/15 11:39 PM
03/10/15 11:39 PM
Posts: 1,973 SoCal
jake4cars
SoCal
ding, ding, we have a winner!! my 4-speed 340 went to where no engine should go and seemed to love it! LOL
Joey
