Re: W2 headache
[Re: Bad340fish]
#1977408
12/27/15 09:18 PM
12/27/15 09:18 PM
Posts: 20,201 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Everybody wants to shift their 9 second or slower small block Mopar engines at 8000 RPM. Except me, LMAO.
Re: W2 headache
[Re: HotRodDave]
#1977435
12/27/15 10:03 PM
12/27/15 10:03 PM
Posts: 8,035 Tulsa OK
Bad340fish
Tulsa OK
RPM=Ruins People Motors lol
EDIT, I didn't realize this was such an old post and I had already said this haha
68 Barracuda Formula S 340
Re: W2 headache
[Re: HotRodDave]
#1977474
12/27/15 10:53 PM
12/27/15 10:53 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
Ran w2 heads for many years with mopar 590 cam...and 3/8 pushrod,,,1st several years with bushed ductile mp rockers..and then last time with crane 1.6 aluminum using the same pushrods...never had to grind the rockers.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
Re: W2 headache
[Re: HotRodDave]
#1977972
12/28/15 05:01 PM
12/28/15 05:01 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
Dang nab it, they are TA rockers. Still think I can fix everything and use em with smaller diameter PRs.
Re: W2 headache
[Re: HotRodDave]
#1978319
12/29/15 01:15 AM
12/29/15 01:15 AM
70AARcuda
las vegas
If they are original TA OEM rocker...I would sell them and find something else..
Tony
Re: W2 headache
[Re: HotRodDave]
#1978604
12/29/15 03:10 PM
12/29/15 03:10 PM
HotRodDave
Kalispell Mt.
How much are they worth and what else is out there? Seems anything else is $1000+ is there anything cheaper that will work ?
Re: W2 headache
[Re: HotRodDave]
#1978613
12/29/15 03:23 PM
12/29/15 03:23 PM
70AARcuda
las vegas
There was a guy over at FABO looking for a set of TA rockers...I bet they are worth pretty close to a grand...if they are in good shape. http://www.forabodiesonly.com/mopar/showthread.php?t=334062&highlight=rockersCrane still has the left and right w2 rocker 1.6 ratio available at summit...and the exhaust are just standard A engine rockers... stands are available from link below which are less expensive then MP..the shafts are the killer...about 300 bucks for a set since they are offset drilled. http://www.billetracingparts.com/Rocker%20Stands.html
Tony
Re: W2 headache
[Re: HotRodDave]
#1978653
12/29/15 04:05 PM
12/29/15 04:05 PM
HotRodDave
Kalispell Mt.
I have stands and shafts already, I guess I could sell the rockers and just buy new rockers to slide on them.
Actually now I look at it more it looks like someone offset drilled the hole in the TA shafts to work on W2 heads, is that acceptable? I did all that work getting geometry where I wanted now I am going to have to do it all over...
Re: W2 headache
[Re: HotRodDave]
#1978658
12/29/15 04:09 PM
12/29/15 04:09 PM
HotRodDave
Kalispell Mt.
I guess I should be clear can I use the crane rollers on the stock bannana groove shaft? Could I use the cranes on the intakes and bushed and nutted 273 rockers on the exhaust?
Re: W2 headache
[Re: HotRodDave]
#1978678
12/29/15 04:40 PM
12/29/15 04:40 PM
Posts: 43,303 Bend,OR USA
Cab_Burge
The Cranes and the Mopar brand are extruded aluminum, not ductile iron so the shafts need to match the rocker material I don't now if your shafts for the ductile iron will work or not Call Crane and ask for Chase Knight and ask him
Re: W2 headache
[Re: HotRodDave]
#1978915
12/29/15 10:12 PM
12/29/15 10:12 PM
70AARcuda
las vegas
I guess I should be clear can I use the crane rollers on the stock bannana groove shaft? Could I use the cranes on the intakes and bushed and nutted 273 rockers on the exhaust? dont know why not...the exhaust w2 is a standard rocker..so if the standard crane roller rocker will work a stock bannana grove shaft...and it works on a offset drilled shaft... I ordered two lefts and two rights 1.6 rockers today...need a couple spares before they stop making them...LOL
Tony
