I carefully dis-assembled, photographed, and documented my one owner 1969 A body 8-3/4 rear end, and this is what I found:
3rd member - bare cast iron, as cast color with lumber crayon marks and paint daubs. No spray paint at all.
Housing - looks semi gloss black, but a lot of people say it was originally a cheap gloss black that faded. Most people agree SG black is the "right" look. I saw black paint overspray droplets inside my housing.
Brake backing plates - most definitely dark gray phosphated (Parkerized), not any kind of paint at all.
Leaf springs - as heat treated color. There are paint daubs over bare metal on the forward end which proves mine had no dip or spray paint. I plan to duplicate the heat treated color by experimenting with gun blueing. There have been several threads here about gun blueing springs.
Hangers, U-bolts/nuts, shock plate, shackles - all bare metal on my car. I believe there is very wide agreement on bare metal. HOWEVER, bare metal does not always mean silvery. Hangers and shackles were stamped from hot rolled steel sheet; shock plates were stamped from hot rolled steel plate; both likely had dark gray mill scale on the top and bottom surfaces but not on the sheared edges. Look at new bare metal U-bolts and nuts in a hardware or parts store, and they are dark colored, not silvery. You can attain a dark color on chemically de-rusted bare metal by wetting with 2 coats of phosphoric acid a week apart and wiping off the second coat. I like Rust Cure (phosphoric acid) for this. Do NOT soak any part in phosphoric acid for very long due to very pronounced acid etching.
