Re: weight difference 8 3/4, 9 in and d60
[Re: wyldebill]
#1770126
03/03/15 02:48 PM
03/03/15 02:48 PM
Posts: 5,897 Florida
Locomotion
FYI, while there are obvious weight differences, the Dana 60 is more "efficient" than an 8 3/4 rear. I've been told by several class racers that in most cases, there has been minimal, if any, change in ET. The Ford 9" is probably the least efficient of the popular rears and the Chevy 12 bolt is the best!
It's been discussed and, for some reason, 30 - 40 lbs sticks in my mind. But it will have to be an apples-to-apples comparison with the same width, spool or sure-grip, etc.
[Re: Locomotion]
#1770127
03/03/15 02:50 PM
03/03/15 02:50 PM
Posts: 1,608 Rudolph, Ohio
moparguy7074
Rudolph, Ohio
Are you trying to start WW III? Saying a 9" is the least efficient! Oh the humanity! LOL
[Re: moparguy7074]
#1770130
03/03/15 03:06 PM
03/03/15 03:06 PM
Locomotion
It would be pointless to argue with the facts. As far as strength, I'm well aware of my old buddy Quicktree's opinion on 9" vs Dana 60's. But despite the ease of gear changes in a 9", a Dana 60 will handle anything most people would ever need. Once the optimum gear ratio is known, the drop-out center benefit isn't that big of a deal. Besides, the expense of maxing out a 9" is astronomical.
[Re: 68shifter]
#1770131
03/03/15 03:08 PM
03/03/15 03:08 PM
Posts: 6,295 U.S.
moparniac
U.S.
My Dana 60 was lighter than the 83/4 it replaced ...the danA had a spool and disc brakes.
Mopar Performance
[Re: moparguy7074]
#1770132
03/03/15 04:25 PM
03/03/15 04:25 PM
Posts: 2,578 sweden
1Fast340
sweden
Dont we need the pinionangle variable to be perfectly sure?
[Re: wyldebill]
#1770137
03/03/15 06:25 PM
03/03/15 06:25 PM
Posts: 2,578 sweden
1Fast340
sweden
i didnt start this to argue witch is best. only asking for weights. i dont thing the parasitic drag is enough to worry with.
Sorry could not resist.
To get back on track i think you could see a substantial difference depending on all the parts inside the axle aswell as other little things here and there all the way down to details like the driveshaft lenght,wish will be different depending on rearend used
[Re: Locomotion]
#1770139
03/03/15 07:18 PM
03/03/15 07:18 PM
Quicktree
dana 60's are for trucks 9s are for racing, you can't argue facts
[Re: moparniac]
#1770140
03/03/15 07:20 PM
03/03/15 07:20 PM
BradH
My Strange S-60 is going to lighten my wallet a whole lot more than the 8-3/4 it's going to replace.
[Re: Quicktree]
#1770141
03/03/15 08:40 PM
03/03/15 08:40 PM
Locomotion
A wider gear selection and the simplicity of a drop-out center section are THE ONLY benefits a 9" has over a Dana 60. Pros and a small percentage of hard core sportsman racers will benefit from a 9". Spend enough money and you can make just about anything stronger/lighter/faster than another competitive part.
But back on topic....
If rear end weight is a concern, most likely to go faster, then efficiency should also be a concern. If you install a heavier, but stronger and less expensive rear and don't slow down, it's worth it! If a Dana 60 will result in similar ET's over an 8 3/4", then it will certainly be faster than a Ford 9" which is heavier and even less efficient than an 8 3/4".
[Re: Locomotion]
#1770142
03/03/15 08:48 PM
03/03/15 08:48 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
So your not considering the double bearing on pinion, aluminum center section, the avaibilty of chromoly housings, bolt through main caps and the ability to back brace benefits? Weird I would consider all of them pluses.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: wyldebill]
#1770144
03/03/15 09:02 PM
03/03/15 09:02 PM
Posts: 52,972 Romeo MI
MR_P_BODY
sorry i asked.
Bee Crazy gave you some decent numbers.. but even Hot Rod said he brakes on the 9" were VERY heavy being they were the LARGE drums
W/O BRAKES W/BRAKES
12-bolt 171 210 Strange S60 191 230 Currie 9-inch 174 238
