Paint wrinkles up #176981
12/28/08 11:38 AM
12/28/08 11:38 AM
Clarksville, Tennessee
monoptn Offline OP
mopar addict
monoptn  Offline OP
mopar addict
I'm painting a dual snorkel hood scoop for my demon. It's new, and fiberglass, of course. I sanded it, then washed it in hot, soapy water and rinsed and dried well. I applied rattle can satin black paint, and it adhered well. But there were a few low sand marks, so after a week, I sanded it, washed it, and applied primer. The primer immediately wrinkled up. I've repeated the process a couple of times, but the primer always wrinkles up. What's going on here?
Re: Paint wrinkles up [Re: monoptn] #176982
12/28/08 12:03 PM
12/28/08 12:03 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
its reacting to the black paint, u most strip to bare fiberglass and start over.
Re: Paint wrinkles up [Re: monoptn] #176983
12/28/08 12:17 PM
12/28/08 12:17 PM
Kingsburg Calif.
Quikshft Offline
Quikshft  Offline
Kingsburg Calif.
Sounds like you've got a compatibility problem. If the black paint you're using sands nicely, why not just add another coat or two? After it dries well sand that smooth and you're good to go ya?
An alternative would be to find another kind of primer which goes on without reaction problems.
Re: Paint wrinkles up [Re: Quikshft] #176984
12/28/08 12:23 PM
12/28/08 12:23 PM
monoptn Offline OP
mopar addict
monoptn  Offline OP
mopar addict
Thanks for the replies. I'll try sanding and applying multiple coats of the satin paint, skipping any future primer.
Re: Paint wrinkles up [Re: monoptn] #176985
12/28/08 03:23 PM
12/28/08 03:23 PM
Jacksonville Florida
elitecustombody Offline
stop using cheap rattle can paint, that is your problem, the solvents in primer eating up the crappy spray paint,strip it all off,apply few coats of sealer/primer,followed by few coats of automotive grade paint that won't fade in couple of months
Re: Paint wrinkles up [Re: monoptn] #176986
12/28/08 03:55 PM
12/28/08 03:55 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
You probably are mixing lacquer with enamel. The solvents in the enamel causes the lacquer to re flow.
Re: Paint wrinkles up [Re: monoptn] #176987
12/28/08 04:26 PM
12/28/08 04:26 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
you can use enamel over lacquer but not lacquer over enamel
