Re: Front wheels don't turn !
[Re: Wedgeman]
#1769343
03/02/15 06:41 PM
03/02/15 06:41 PM
Posts: 20,665 in a cattle trailer down by th...
Guitar Jones
Just off the top of my head, calipers could be froze, flex lines might be restricted not allowing fluid back to the master cylinder or there may not be any free play in the brake pedal pushrod to the master cylinder leaving constant pressure on the brakes.
I would also check to see if any rubber parts that touch brake fluid are swollen. That would indicate contamination or the fluid.
[Re: Wedgeman]
#1769345
03/02/15 06:49 PM
03/02/15 06:49 PM
Posts: 3,749 Chowchilla,ca
Chassisman
Chowchilla,ca
When I installed those disc brakes in the front, I put brand new parts all around (calipers-lines-MC).....bleeded them beyond reasonable !
Dan
If your car was a brake drum front car you need the correct porportioning valve. Drum brake cars have more residual pressure to hold the shoes closer to the drum. Disc brake cars dont need as much. We use 10 psi on drum cars and 2 psi on disc cars. Look into that being the cause.
[Re: Wedgeman]
#1769350
03/02/15 07:48 PM
03/02/15 07:48 PM
Posts: 9,881 MI, usa
dvw
MI, usa
I plan to istall rear disc brake using GM calipers, Cherokee rotors and Dakota Master cyl...
Should use the Dakota prop valve ?
Dan
No, buy an adjustable valve. I wouldn't worry to much about the brake drag, pretty normal. Make sure the pads move nice in the brackets, it'll be fine.They're cheap and then you can get it where you want it. If It's a drag only car with skinny fronts put it in the front brake line. Doug
[Re: Wedgeman]
#1769352
03/02/15 09:34 PM
03/02/15 09:34 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Ok.........so get an adjust prop valve for the front....what about the rear ??? direct from the Dakota MC ?
Yep..... on your fronts.. loosen the bleeder and spin the wheel.. if it turns freely then you have a issue.. I dont have any stop within a turn(disc brakes)... also a little trick is run your front bearings a little loose to get just a MINOR bit of wobble to kick the pads back quicker
[Re: Wedgeman]
#1769355
03/02/15 10:31 PM
03/02/15 10:31 PM
MR_P_BODY
Let me get this.....
If I put the prop valve for the front and direct from the master to the rear, there will be more braking from the rear than the front ??
You are correct.. if you run big tires on the rear and skinnies up front the fronts dont have the braking ability so you want more from the rears
[Re: Wedgeman]
#1769357
03/02/15 11:09 PM
03/02/15 11:09 PM
MR_P_BODY
Ok thanks P !
But it doesn't solve my problem of front discs dragging..........
No it doesnt.. your pads are dragging for some reason.. either the pressure doesnt let them back or they are rusty on the sliders... JMO
