Page 1 of 3 1 2 3
Front wheels don't turn ! #1769342
03/02/15 06:35 PM
03/02/15 06:35 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
I'm getting ready to start the new drag season beginning in May, and drop my ET's again...
I notice there is a lot of restriction coming from
the front rotors....
I jacked up the front of my car, and try to turn by hand the tires. With a good swing, they will barely make a full turn because there is a strong friction from the brake pads.
The car is also a dog to push in neutral...
Where is the problem ?
A bad MC that is not retracting the pistons ?
Bad calipers? (from '74 Dart new)
What are your ideas on the subject?
Dan
67 Barracuada
best 60 ft 1.30sec 6.40 1/8 mile
Re: Front wheels don't turn ! [Re: Wedgeman] #1769343
03/02/15 06:41 PM
03/02/15 06:41 PM
Guitar Jones Offline
Just off the top of my head, calipers could be froze, flex lines might be restricted not allowing fluid back to the master cylinder or there may not be any free play in the brake pedal pushrod to the master cylinder leaving constant pressure on the brakes.
I would also check to see if any rubber parts that touch brake fluid are swollen. That would indicate contamination or the fluid.
Re: Front wheels don't turn ! [Re: Guitar Jones] #1769344
03/02/15 06:45 PM
03/02/15 06:45 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
When I installed those disc brakes in the front,
I put brand new parts all around (calipers-lines-MC).....bleeded them beyond reasonable !
Dan
Re: Front wheels don't turn ! [Re: Wedgeman] #1769345
03/02/15 06:49 PM
03/02/15 06:49 PM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
Dan
If your car was a brake drum front car you need the correct porportioning valve. Drum brake cars have more residual pressure to hold the shoes closer to the drum. Disc brake cars dont need as much. We use 10 psi on drum cars and 2 psi on disc cars. Look into that being the cause.
Re: Front wheels don't turn ! [Re: Wedgeman] #1769346
03/02/15 06:51 PM
03/02/15 06:51 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Make sure the brake pedal pivot is well lubed and coming all the way up when released. DAMHIK
If you like drag racing, support your local track.
Re: Front wheels don't turn ! [Re: Chassisman] #1769347
03/02/15 06:53 PM
03/02/15 06:53 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
I really don't remember...........
By looking at it, can you tell if the prop valve is for drum or disc brakes ?
Dan
Re: Front wheels don't turn ! [Re: Wedgeman] #1769348
03/02/15 06:55 PM
03/02/15 06:55 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
I plan to istall rear disc brake using GM calipers, Cherokee rotors and Dakota Master cyl...
Should use the Dakota prop valve ?
Dan
Re: Front wheels don't turn ! [Re: Wedgeman] #1769349
03/02/15 07:05 PM
03/02/15 07:05 PM
Try loosening the bleeder vale and see if it has pressure or not If it has pressure you may have a residual valve in the brake master cylinder keeping pressure on the front disc brakes, not really needed if the master cylinder is mounted above the calipers If the master cylinder is mounted below the brake calipers you will need a 3 lb or so, not 10 lbs residual valve to prevent the calipers draining back into and overfilling the master cylinders. Let us know what you find out
Re: Front wheels don't turn ! [Re: Wedgeman] #1769350
03/02/15 07:48 PM
03/02/15 07:48 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Dan
No, buy an adjustable valve. I wouldn't worry to much about the brake drag, pretty normal. Make sure the pads move nice in the brackets, it'll be fine.They're cheap and then you can get it where you want it. If It's a drag only car with skinny fronts put it in the front brake line.
Doug
Re: Front wheels don't turn ! [Re: dvw] #1769351
03/02/15 09:27 PM
03/02/15 09:27 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Ok.........so get an adjust prop valve for the front....what about the rear ??? direct from the Dakota MC ?
Re: Front wheels don't turn ! [Re: Wedgeman] #1769352
03/02/15 09:34 PM
03/02/15 09:34 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yep..... on your fronts.. loosen the bleeder and spin
the wheel.. if it turns freely then you have a issue..
I dont have any stop within a turn(disc brakes)...
also a little trick is run your front bearings a
little loose to get just a MINOR bit of wobble to
kick the pads back quicker
Re: Front wheels don't turn ! [Re: MR_P_BODY] #1769353
03/02/15 10:05 PM
03/02/15 10:05 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
I just tried loosening the bleeder screws and turn the tires.....the pads are still sticking to the rotor and making it hard to turn by hand.....
Re: Front wheels don't turn ! [Re: Wedgeman] #1769354
03/02/15 10:08 PM
03/02/15 10:08 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Let me get this.....
If I put the prop valve for the front and direct from the master to the rear, there will be more braking from the rear than the front ??
Re: Front wheels don't turn ! [Re: Wedgeman] #1769355
03/02/15 10:31 PM
03/02/15 10:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You are correct.. if you run big tires on the rear
and skinnies up front the fronts dont have the braking
ability so you want more from the rears
Re: Front wheels don't turn ! [Re: MR_P_BODY] #1769356
03/02/15 10:42 PM
03/02/15 10:42 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Ok thanks P !
But it doesn't solve my problem of front discs dragging..........
Re: Front wheels don't turn ! [Re: Wedgeman] #1769357
03/02/15 11:09 PM
03/02/15 11:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Ok thanks P !
No it doesnt.. your pads are dragging for some reason..
either the pressure doesnt let them back or they
are rusty on the sliders... JMO
Re: Front wheels don't turn ! [Re: MR_P_BODY] #1769358
03/03/15 01:02 AM
03/03/15 01:02 AM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
After inspections, I let off the bleeders again and it seems like it is always pushing the piston in the caliper, like a constant small pressure...
The brale pedal has lots of freedom to retract...
Dan
Re: Front wheels don't turn ! [Re: Wedgeman] #1769359
03/03/15 03:49 AM
03/03/15 03:49 AM
S.E. Minnesota
gtsdude Online happy
gtsdude  Online Happy
S.E. Minnesota
do you have the correct length pushrod from the brake pedal to master cylinder? Also make sure the pedal is going back all the way, When I switched to manual brakes my pedal did not come all the way back and I had the same problem you do.
Re: Front wheels don't turn ! [Re: gtsdude] #1769360
03/03/15 08:15 AM
03/03/15 08:15 AM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
If there Wilwoods join the club.
Re: Front wheels don't turn ! [Re: OUTLAWSSAA] #1769361
03/03/15 10:27 AM
03/03/15 10:27 AM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Are there better quality callipers somewhere to prevent this ?
Or may be a bigger bore master cylinder ?
Dan
Page 1 of 3 1 2 3
