cam or torque convertor selection first?
#1768260
03/01/15 02:25 PM
03/01/15 02:25 PM
Posts: 916 Arizona
Chucklehead
Arizona
I,m building a e body street /strip cuda. 470 lo deck stroker. When looking at cam selection they ask what stall convertor. When I look at convertors that ask about the cam/torque. So which would you select first to determine the other.
Still Broke
Re: cam or torque convertor selection first?
[Re: Chucklehead]
#1768261
03/01/15 02:33 PM
03/01/15 02:33 PM
Posts: 52,972 Romeo MI
MR_P_BODY
You have to think of the whole package... so when you are going to buy a cam you have to have in mind what conv you plan on going with.. if you started from scratch then most likely your gonna buy both at the same time(or close).. so think ahead... but be realistic since its a street car mainly
[Re: MR_P_BODY]
#1768263
03/01/15 02:53 PM
03/01/15 02:53 PM
Posts: 240 Ft. Wayne, IN.
QTR MILR
Ft. Wayne, IN.
I would think about what I was willing to drive on the street converter wise. Then order the cam based on that. Then when you have all the specs. for the cam and the rest of the motor combination give all that info to the converter company. I want the converter guy to have all the info so they can set it up where it needs to be.
Scott
69 Satellite, 3650lb street car... Dunnuck Racing pump gas 440. Best of 10:60@127...
[Re: QTR MILR]
#1768264
03/01/15 03:15 PM
03/01/15 03:15 PM
MR_P_BODY
What I did on my last ride(street/strip) I tried to set up the total package... what rpm will I want as a max rpm.. so that takes the gear and tire and conv slippage to figure that then base the cam on that and the heads.. I came within 100 rpm but that was due to the slippage I used was slightly high.. I had a idea what I wanted for conv stall... when I started that build I knew what I wanted for ET and had a good idea what I could build the car to weight wise.. so base on that calculated what HP was needed and built on that idea.. it came out with a bit more HP than I needed but I can slow it down if needed
[Re: d-150]
#1768266
03/01/15 03:42 PM
03/01/15 03:42 PM
MR_P_BODY
cam,converter then rearend gear.the cam determines the other 2
You guys are thinking strictly track.. thats not how I think about street/strip cars that mainly spend their time on the street... but as usual this is my opinion
[Re: gch]
#1768268
03/01/15 03:49 PM
03/01/15 03:49 PM
MR_P_BODY
On a street car I look at my rear gear and tire height and then work backwards from there.
Same here.. what can I live with for driving RPM
[Re: Cab_Burge]
#1768271
03/01/15 07:49 PM
03/01/15 07:49 PM
Posts: 714 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
I think head flow, rocker arm ratio are 1st. Then select a cam to use the head airflow. Then dyno the engine. adjust your rear gear/tire so your cruise RPM is around peak torque (best BSFC). send info to the converter guy so he/she can nail the converter on the 1st try. you will have a bad street ride.
Joe
Without Data, you’re just another guy with an opinion.
