turboing a sb,how expensive? #1765444
02/28/15 08:11 PM
02/28/15 08:11 PM
Pa. U.S.A.
moparborn Offline OP
Pa. U.S.A.
I am thinking of putting a turbo or two on the truck and was wondering
what parts are available the approximate cost may to be complete.
Re: turboing a sb,how expensive? [Re: moparborn] #1765445
03/01/15 03:07 PM
03/01/15 03:07 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Dizuster (member here) is developing turbo kits for small blocks. They should be available later this year.
Doug
Re: turboing a sb,how expensive? [Re: dvw] #1765446
03/03/15 02:38 AM
03/03/15 02:38 AM
East Brunswick, NJ
finadk Offline
finadk  Offline
East Brunswick, NJ
MY son put together a turbo on his 02 Mustang for under $5000. But there were some aftermarket parts (piping, intercooler etc) for that application.
You could probably use methanal (washer fluid) to cool the intake charge and save the cost and complexity of an intercooler.
Another option is a bolt on Paxton supercharger.
http://www.paxtonauto.com/product.php?id=127
Personally I do not like them, the one on the Mustang was awfully loud (not is a good way to my 50 year old ears) but it was faster than hell.
Tuning is a big concern, even with EFI it will be tough to dial in.
Good luck
Scott
Scott 1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed) 2002 Dodge Ram 1500 Quad Cab 1976 Corvette
Re: turboing a sb,how expensive? [Re: moparborn] #1765447
03/03/15 11:41 AM
03/03/15 11:41 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Depends on your fabrication skills. If you can bend pipe and weld, not much. If you have to pay somebody to do it all, it will get expensive. Re-manned turbos can be found cheap...exhaust pipes and cheap, carb mods you can do or send out... So ball park $800-$3000
Coming soon!!!!
Re: turboing a sb,how expensive? [Re: finadk] #1765448
03/03/15 01:53 PM
03/03/15 01:53 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
The turbo was loud?
Did he have the exhaust dumped or use an open blow off valve?
My hot rod had 3" straight pipes with no mufflers.
https://www.youtube.com/v/9QMuJ6Ngmfs
- Stu Harmon
Re: turboing a sb,how expensive? [Re: feets] #1765449
03/03/15 04:17 PM
03/03/15 04:17 PM
East Brunswick, NJ
finadk Offline
finadk  Offline
East Brunswick, NJ
The belt driven supercharger was loud. The Paxton and Vortech are essentially a turbo being driven off of a belt from the crankshaft instead of exhaust gasses.
It whined at idle but HOWLED at high RPM great on the top end but impossible to sneak home at night.
Scott
Re: turboing a sb,how expensive? [Re: finadk] #1765450
03/04/15 12:00 PM
03/04/15 12:00 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Scott
I had a Paxton on a 440, no louder than a bad power steering pump. At WOT you couldn't even hear it. Turbo cars are typically quiet until you get why up in the rpms and they start to whine.
Re: turboing a sb,how expensive? [Re: Mr.Yuck] #1765451
03/04/15 01:24 PM
03/04/15 01:24 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
this is a good read. pretty inexpensive for the power output. I would want the car to run faster than it does for that much effort though.
http://www.forabodiesonly.com/mopar/showthread.php?t=227729
Re: turboing a sb,how expensive? [Re: chrisf] #1765452
03/04/15 01:33 PM
03/04/15 01:33 PM
Dirty Dena, Maryland
dodge turbo Offline
dodge turbo  Offline
parts to account for
Turbo
wastgate
blow off valve
carb or fuel injection
fuel pump
fuel pressure regulator
intercooler? or meth? or e85?
piping
headers or use flip exhaust manifolds
my turbo was $900, custom borg warner
vs racing blow off (100) and wastgate (150) (ebay grade) still good stuff
carb: stock holley with hanger18 mod's
used aeromotive fuel pressure reg with fittings (150)
fuel pump(s) walbro gsl392's 115 a piece
vs racing 4inch core intercooler (150)
misc pipe and flanges (300)
pacesetter shorty headers (150)...manifolds are free
you dont need a pipe bending just buy a pipe with combo bends if you can weld your own stuff
hop on turbomustangs.com.....tons to look at on there
78 Adventurer 150small block turbo'd 360w/Borg S475....smoke'em
Re: turboing a sb,how expensive? [Re: moparborn] #1765453
03/04/15 02:45 PM
03/04/15 02:45 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
What kind of power are you looking for? For the cost and effort there may be better bang for buck options.
Re: turboing a sb,how expensive? [Re: dodge turbo] #1765454
03/04/15 03:08 PM
03/04/15 03:08 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
You can't flip the exhaust manifolds on LA, B or RB engines.
On the LA the two center exhaust ports are funky shaped. They won't seal when inverted.
B and RB manifolds will block the spark plug holes when inverted. You can't get the spark plugs in. There is one manifold that will work but I think it came off a van.
- Stu Harmon
Re: turboing a sb,how expensive? [Re: feets] #1765455
03/04/15 03:23 PM
03/04/15 03:23 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I thought Dizuster flipped his manifolds? He has a SB w/ logs facing forward. I'd think shorty headers would work on a SB as well.
Re: turboing a sb,how expensive? [Re: feets] #1765456
03/04/15 05:08 PM
03/04/15 05:08 PM
dodge turbo Offline
dodge turbo  Offline
mine are flipped side to side. so yes you can. not flipped upside down
Re: turboing a sb,how expensive? [Re: dodge turbo] #1765457
03/04/15 09:33 PM
03/04/15 09:33 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Semantics.
Flipped generally means head over heels. You can swap some manifolds side to side but on LA engines but not on B/RB. The passenger side rear outlet will interfere with the steering box and motor mount.
- Stu Harmon
Re: turboing a sb,how expensive? [Re: feets] #1765458
03/04/15 09:44 PM
03/04/15 09:44 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
small grind on the drivers manifold and magnum manifolds work well on small blocks.
Re: turboing a sb,how expensive? [Re: chrisf] #1765459
03/04/15 10:54 PM
03/04/15 10:54 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Dizusters are swapped right to left.
Doug
Re: turboing a sb,how expensive? [Re: chrisf] #1765460
03/04/15 11:10 PM
03/04/15 11:10 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Not so much early small port 273's, very careful placement is needed to ensure a seal. Also, I had to grind a big lump off the rear of the driver's side head to get the magnum's to fit an 87 318.
Don't be the exception.
Re: turboing a sb,how expensive? [Re: moparborn] #1765461
03/06/15 01:46 PM
03/06/15 01:46 PM
East Brunswick, NJ
finadk Offline
finadk  Offline
East Brunswick, NJ
There are a few ebay options for Chevy guys. They all need fabrication even for a chevy but could be adapted to a MOPAR. Might be a good place to start.
http://www.ebay.com/itm/SBC-STAINLESS-ST...de4&vxp=mtr
http://www.ebay.com/itm/NEW-Small-Block-...d1b&vxp=mtr
