Help set up my fuel system
#1763614
02/26/15 02:50 PM
02/26/15 02:50 PM
Posts: 5,166 CT
GTX MATT
CT
Need to upgrade my fuel system on my street/strip Satellite. It's adequate for street use but has started to run out of fuel at the top of third when I've gotten on it on a hill (highway onramp). Right now the engine is in the 525 HP neighborhood, car should run mid 11s but hasn't been down the strip yet as I'm still sorting it out. Plans in the near future are for headwork and 600-650 HP. I'm thinking 1/2 inch pickup and fuel line up to the mechanical pump, with one Holley black pump. 9/16 line from the pump to carb with a dead head fuel pressure regulator. Does this sound sufficient? I would think that this should be more than enough but I really don't know.
Re: Help set up my fuel system
[Re: GTX MATT]
#1763615
02/26/15 03:19 PM
02/26/15 03:19 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Why the 9/16 line... the 1/2 is your choke/flow and is more than enough.. I assume you would run on the mech pump and turn on the black when racing
[Re: rt66jim]
#1763617
02/26/15 04:48 PM
02/26/15 04:48 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I went with 1/2" stainless tubing from tank to frame rail by pump, -8 hose from tubing to pump then back to the tubing from pump to regulator, 3/8" tubing from regulator to each carb on a 572 hemi. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: GTX MATT]
#1763619
02/26/15 08:01 PM
02/26/15 08:01 PM
MR_P_BODY
Sorry Mr P - I meant 3/8 I just doubled it when I typed it up.
Is there a reason I couldn't run the black full time?
You would be getting marginal with 3/8.. I would run 1/2 just in case... you can run the pump all the time
[Re: GTX MATT]
#1763620
02/26/15 08:22 PM
02/26/15 08:22 PM
Posts: 43,284 Bend,OR USA
Cab_Burge
I use to use a Holley blue 110 GPH electric pump between the tank and the Carter 3 valve NASCAR mechanical fuel pump on the motor without a regulator on my old NHRA 426 C.I. Max Wedge Stocker. The mechanical fuel pump will and does act as a pressure regulator My message is don't waste your time and money on a regulator now before trying that electric pump working in series with your mechanical pump A 1/2 inch O.D., 7/16 I.D. line, is fine as far as I've used for motors up to 700+ HP My new drag car will have a 5/8 O.D., #10 AN size, hardline from the pump to the pressure reg. mounted up front in front of the carb. due to shooting for 850 +HP carbureted now with EFI in the potential future for more power with a power adder later. I'll use #12 AN from the tank to the 500 GPH electric pump to start with, over build it once instead of doing it twice BTW, how many GPH is that Holley black pump rated at
[Re: QTR MILR]
#1763624
02/27/15 12:37 PM
02/27/15 12:37 PM
Posts: 1,627 anywhere@ anytime
actionange
anywhere@ anytime
I like the KISS method.... I ran 1/2 line up to the passenger fender to the regulator then used two 3/8 lines from there to the carb. I used the Holley Blue pump with regulator. Works fine on my car. No pressure problems. My motor is over 650hp. I run it on the track and street with no issues.
[Re: actionange]
#1763625
02/27/15 01:43 PM
02/27/15 01:43 PM
Posts: 5,166 CT
GTX MATT
CT
Thanks for the info guys.
Heres another question, looks like the Holley Black uses 3/8 NPT input and output. I can't find a flare nut for 3/8 NPT for 1/2 inch line anywhere, what gives?
[Re: GTX MATT]
#1763626
02/27/15 01:47 PM
02/27/15 01:47 PM
MR_P_BODY
Put a adapter from 3/8 to 1/2.... also I like to drill out the adapters to get a bit more flow
[Re: StealthWedge67]
#1763633
03/04/15 03:20 AM
03/04/15 03:20 AM
MR_P_BODY
Will a mechanical pump draw through an electric pump when on the street just driving around? I wouldn't mind having an electric pump at hand for race duty, but it would be nice to be able to drive around town on just the mechanical pump. (sorry for the hi-jack)
My buddy does it on his 460.. mech pump with a holley blue in the rear... so yeah I guess it works..he has been doing it about 6 years now... he runs 11.50 on motor and 10.80 on a little spray
