Page 14 of 15 1 2 12 13 14 15
Re: 5.7 Hemi in a 67 Barracuda [Re: Daty Rogers] #17627
08/20/06 10:35 AM
08/20/06 10:35 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Off the top of my head, I have no idea.
Do you have the schematic? It should have come with one.
If not we can probably dig one up.
Re: 5.7 Hemi in a 67 Barracuda [Re: ZIPPY] #17628
08/21/06 08:29 AM
08/21/06 08:29 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
They are the same thing....
MIL= Malfunction Indicator Lamp (the proper dcx term)
CEL= Check Engine Light (general shop term for all brands)
MP wanted to make it easy as possible for guys with older cars to install the crate motor, so they stripped the PCM down to the bare essentials to make it run in that application, and made it 100% simpler than the production wiring/computer. Open loop/no
02 sensors at all. Pretty much all your sensor readings are on the intake side + temperature related stuff. Must use a hydraulic shifted trans, also.
Also earlier there was a comment from somebody above who believed the 2 crate engine intake manifolds might be the same....they are machined differently so I guess that'd mean they aren't the same. The EFI manifold is machined for injectors wheras the carb manifold is not...not to argue or be contrary, just fyi/general info.
so how the heck are you supposed to tune it without any feedback? and where do you get any advantage of EFI without feedback from O2 sensors? seems like a waste to me.
2017 Grand Cherokee Overland
Re: 5.7 Hemi in a 67 Barracuda [Re: patrick] #17629
08/21/06 09:44 AM
08/21/06 09:44 AM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
My gut feeling is that it's got a solid tune based on a stone-stock 5.7L Hemi. Maybe it's rich enough to use headers and a good exhaust, I ASSume that the engineers that put that tune together could see that writing on the wall. Narrow-band O2 is primarily useful in emissions calibrations to keep the cats happy, and that happens at 14.7:1. Best power and best economy both occur elsewhere, so if the calibration is ON, it ought to be a great running engine. Most narrow-band O2 cars drop in to open loop at WOT, so it's the same type of system at that point.
Clair
BTW, Daty,
How's it looking for the Mini Nats? Time is slipping away over here, and the gap between what I've got to do and the time I've got to do it in keeps getting wider. I hope you're in better shape. Check out my high-dollar masking tape holder, as of about 4PM yesterday...
Re: 5.7 Hemi in a 67 Barracuda [Re: Clair_Davis] #17630
08/21/06 07:16 PM
08/21/06 07:16 PM
Texas
Daty Rogers Offline OP
World's Greatest Husband. I love you Robyn
Texas
I've got the ever-widening gap problem too, had to undo some things (hate that!) and got it back on stands now. What's that saying, 90% done and 90% to go? I'm at the 95 percentile...
Talked with the MP tech line, he said to use the alternator hookup on the engine harness, the pcm will provide alternator regulation. He also said the pcm is open loop (no O2 sensors) so it'll run a touch rich (fine considering I have headers). He said they may not get the best economy. Duelich (sp?) dynoed one last year in Hot Rod magazine, I need to dig it up and see what A/F ratios they found, it seemed reasonable IIRC.
Love the tape despenser, mine is still holding the paper towell roll proudly!
-Daty
Re: 5.7 Hemi in a 67 Barracuda [Re: ZIPPY] #17631
08/21/06 07:22 PM
08/21/06 07:22 PM
Texas
Texas
it came with a schematic but shows general line running and not individual wires, I'll call MP tomorrow and see if they have something more detailed than what came with the motor.
-Daty
Re: 5.7 Hemi in a 67 Barracuda [Re: Clair_Davis] #17632
08/22/06 09:21 AM
08/22/06 09:21 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
Clair
BTW, Daty,
true, NB O2's are really only useful around stoich. but that's precisely why I'd want EFI--to have a consistant stoich part throttle A/F ratio independent of ambient temp, humidity, fuel formulation, etc. to maximize economy. WOT on most OEM systems (except maybe some of the latest ones) go open loop anyways so then you're looking at your a/f ratio only being as good as your map. buut, if open loop varies from 11:1 to 13:1 depending on humidity, bariometric pressure, ambient temp, fuel formulation, etc. it probably won't make too much difference in performance, but it would make a HUGE difference in part throttle economy (fuel mileage). as it is with my carb (600 eddie), I need to swap needles in the spring and fall as the temp drops, and the gas formulations are changed. I don't see how running open loop efi would alleviate that--except it would be uploading a "summer" map and a "winter" map.
Re: 5.7 Hemi in a 67 Barracuda [Re: patrick] #17633
08/22/06 09:49 AM
08/22/06 09:49 AM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
I'd bet on the open loop map is probably 13:1 out of the box at worst, with a target of somewhere around 14.7:1 under most light-medium throttle situations. You're not going to get your best mileage at 14.7:1, you'd need to be much leaner, like 16-17:1 for that. You can run that lean with no problems IF you're running light throttle and lots of advance. Unfortunately, that's not where the cat converters do their best work, and certain emissions (NOx, I think) go up. My understanding is that GM got hammered for this back in the 80's-90's because they programmed in a "highway mode" on their EFI systems, and although it got better mileage, it didn't meet EPA's req's. I think that's a shame, since you really have to be steady-state + light-throttle for a while to kick in to highway mode. That was also open-loop, but the computer would check back periodically by going back closed on some regular basis. I think this functionality is still in the GM codes, just disabled.
That's neither here nor there for Daty's setup. I think with a MAP giving a baseline baro every time you start up, air intake temp, and a known VE for the engine, you really don't NEED an O2 if you're not running cats.
Clair
Re: 5.7 Hemi in a 67 Barracuda [Re: Clair_Davis] #17634
08/22/06 11:24 AM
08/22/06 11:24 AM
Texas
Texas
It could also take readings at intervals to see if adjustments are needed, don't know. When I talked with Matt at Glendora he said it runs nice and guiet but can scream when asked to so it's a thrill to drive. The only real problem he's had is the fuel gets too hot and shuts down the fuel pump. (6 hours in the desert will do that). We talked about his lines were ran and how I ran mine, his return dunps above feul level and there is no cooler on the line, so the thinking is his fuel is getting hot and areated. I ran my return into the original sender (removed the sock) and my supply is in a sump in the back, and have a line cooler post pump. He's thinking about rerouting some of his lines and see if it fixes the issue.
-Daty
Re: 5.7 Hemi in a 67 Barracuda [Re: Daty Rogers] #17635
08/22/06 11:57 AM
08/22/06 11:57 AM
Texas
Texas
Zippy,
update on the alternator and voltage regulator issue. The wiring diagram Rich (the DC/MP call guy) has the same diagram I have that came with the motor, Rich dug around with my question and he email Eric (who designed/built the engine management system, pcm, wiring, everything) and he said I do need a late 70's VR and told me the wiring layout AND is sending me a copy of the diagram I need.
Kudos out to Rich and Eric at MP/DC! Show your bossmen how much I appreaciate the help!
Playing the old 60's Dodge/Plymouth commercial instead of generica musica or heavy handed sales blasting when on hold is a stroke of genious!
-Daty,
Re: 5.7 Hemi in a 67 Barracuda [Re: Daty Rogers] #17636
08/22/06 12:30 PM
08/22/06 12:30 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Dont know if it was posted, but what does the MP crate hemi 5.7 go for? is there a 6.1 coming?
Re: 5.7 Hemi in a 67 Barracuda [Re: moper] #17637
08/23/06 01:24 AM
08/23/06 01:24 AM
Texas
Texas
Ive seen prices from 7200 to 8000, efi is ~500 more. I got my efi crate for 7300 plus tax.
-Daty
Re: 5.7 Hemi in a 67 Barracuda [Re: Daty Rogers] #17638
08/24/06 02:17 AM
08/24/06 02:17 AM
Texas
Texas
This is for 71Challenger, it's a compilation of some of the various threads I and others started dealing with a 5.7 swap into an older car.
https://board.moparts.org/ubbthreads/favl...amp;postmarker=
These should help, I'd probably be done by now if it weren't for my really screwy work schedule. After watching what whiteboy and others went thru on takeout motors I think the crate motor is a much easier swap, and if I did it over again I'd probably opt for the carb instead of the EFI version.
-Daty
Re: 5.7 Hemi in a 67 Barracuda [Re: Daty Rogers] #17639
08/24/06 07:37 AM
08/24/06 07:37 AM
St Charles MO
70Coronet500Vert Offline
St Charles MO
Thanks for post Daty.
I have a 13yr old that wants a mopar. The idea cooking in my overheated little head is to get a 5.7 for the coronet, I want the EFI, and swap the 360 into whatever car we get him.
So I am paying attention to these threads and hope they make it to the best of Moparts!
No matter how responsible he may seem, never give your gun to a monkey!
1970 Coronet Vert
1972 Charger
1974 Satellite Sebring Plus Sundance
2001 Ram 4x4
2002 Intrepid
2006 300C
Re: 5.7 Hemi in a 67 Barracuda [Re: 70Coronet500Vert] #17640
08/25/06 03:33 AM
08/25/06 03:33 AM
Texas
Texas
Zippy is going to tech archive this entire thread one of these days, I imagine it'll happen when mine is on the road. I've learned a LOT over the past year (it's been that long?) on swapping a crate hemi, if I had to do it over I wouldn't piddle fart around so much and just dive right in.
-Daty
Re: 5.7 Hemi in a 67 Barracuda [Re: Daty Rogers] #17641
08/25/06 12:43 PM
08/25/06 12:43 PM
-Daty
Thanks Daty!!! You Da Man!!!!!
Re: 5.7 Hemi in a 67 Barracuda [Re: Daty Rogers] #17642
08/25/06 12:53 PM
08/25/06 12:53 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Soon as you're done
Re: 5.7 Hemi in a 67 Barracuda [Re: ZIPPY] #17643
08/26/06 09:56 AM
08/26/06 09:56 AM
michigan
440whiteboy Offline
440whiteboy  Offline
michigan
daty didnt you tell zippy that we were done for- before we started! ha ha
They only see Stars...
when hit by a Mopar!
Re: 5.7 Hemi in a 67 Barracuda [Re: 440whiteboy] #17644
09/03/06 03:12 AM
09/03/06 03:12 AM
Texas
Texas
Major progress today, the electical system is all hooked up and no magic smoke releases! We had to jumper the starter relay with a screwdriver but the relays click and it turns over! There's some work to do on the passenger side yet, but it's looking great and sounding better!
DD (my wife and constant supporter) ran out and said "You are NOT starting this with me NOT being here!" No worries, no fuel yet sweetie...
Fuel is next...
in a week or so this thread is one year old.
-Daty
Re: 5.7 Hemi in a 67 Barracuda [Re: Daty Rogers] #17645
09/03/06 03:55 AM
09/03/06 03:55 AM
okla.
O
okie Offline
okie  Offline
O
okla.
Hurry Daty! Hurry!!! It is time. Keep me informed on the progress. RONNIE
Re: 5.7 Hemi in a 67 Barracuda [Re: okie] #17646
09/03/06 04:18 AM
09/03/06 04:18 AM
Texas
Texas
Thanks Ronnie, no idea how much that push meant. I'm almost sunk into self pity because of how its dragged on and remembered what you're delaing with and just how perfect your FC7 Dart really is. You're am inspiriation old man (thats a good thing) to this old man. Coming down Sunday? If so I'd love for you to swing you by the place to check out the damage, it's on the way home.
972-680-9759, 972-948-4845
-Daty
