Re: 67 coronet rt stripe?
[Re: KOS]
#1761664
02/24/15 04:17 PM
02/24/15 04:17 PM
Posts: 27,466 So Cal
autoxcuda
So Cal
This picture was taken in the Spring of 1967. Check out the black stripe. This car was delivered to the dealership with it. But it doesn't have the Dodge lettering. Maybe the ad was of a prototype.
explain this then.........factory did strange things just like they said my dads 67 Z28 never came factory with headers supposed to be dealer only install....well it did confirmed by numerous specialists.
Have you ever painted any stripes? If so, what was the step-by-step process you used?
As for the Z28 factory headers were an well known factory option in 1967 and 1968. They came in the trunk and the dealer installed them upon delivery. There are many different cars where this process was used.
i assumed it was a decal(sticker)not painted...even so how do you explain how the other coronet mentioned came with the stripe out of the factory?also the header deal that came in the trunk of the z28s which everybody knows isnt the case with the old mans car...they came factory installed not dealer....if you like to wager on it i could prove it.
How come the one Coronet mentioned/pictured does not have the Dodge lettering/cutout but the advertisement does?
[Re: autoxcuda]
#1761667
02/24/15 04:54 PM
02/24/15 04:54 PM
KOS
good question id like to know the answer also.......im just saying factory did weird stuff who knows for sure. my big question is did the dealer read the fender tag(or how does it work)and say we have to paint a stripe on this one?
Factory built cars as planned. They had various large build plan sheets that had codes that were on the fender tag and build sheet, and much more to accompany cars down line.
They did not make stuff up out of the blue. They do make some minor mistakes that are not caught.
The dealer does not really check tag. They did not have info to completely decipher them even in 67. And they can do pretty much whatever they want to the car before it's sold. It's their car (sorta sometimes).
well you just answered my question......it is on my fender tag white horizontal accent stripe so whatever it means the factory put it on the car correct?
[Re: KOS]
#1761668
02/24/15 05:00 PM
02/24/15 05:00 PM
autoxcuda
So Cal
And the accent stripe is commonly called a pin stripe.
Here's the factory information:
http://www.hamtramck-historical.com/dealerships/1967DodgeColorAndTrim-03.shtml
[Re: autoxcuda]
#1761670
02/25/15 01:02 AM
02/25/15 01:02 AM
KOS
did i miss something??....where does it say accent stripe??? heres the fender tag code .... LL1 p6x ax68
