harmonic damper install ? #175997
12/27/08 12:01 PM
12/27/08 12:01 PM
Jarrettsville, MD
tywebb2 Offline OP
super gas
tywebb2  Offline OP
super gas
Jarrettsville, MD
How snug should the fit between the damper and crank be? I just installed a new 440 Souce SFI damper and I got it on but it took some effort with an install tool and LARGE wrench.
'72 440 Cuda
11.673 @ 115.91 w/1.663 60'
Re: harmonic damper install ? [Re: tywebb2] #175998
12/27/08 12:39 PM
12/27/08 12:39 PM
DELAWARE
TONY_DAGOSTINO Offline
DELAWARE
snug + tight is good
id be concerned if it was a loose fit
Re: harmonic damper install ? [Re: TONY_DAGOSTINO] #175999
12/27/08 12:45 PM
12/27/08 12:45 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Snug slip fit.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: harmonic damper install ? [Re: MoparforLife] #176000
12/27/08 05:21 PM
12/27/08 05:21 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Yeah, they don't go on easy.
Re: harmonic damper install ? [Re: tywebb2] #176001
12/27/08 05:32 PM
12/27/08 05:32 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
They key is for indexing only, the friction of the fit is what keeps it in place. Tight is good.
Re: harmonic damper install ? [Re: tywebb2] #176002
12/27/08 09:15 PM
12/27/08 09:15 PM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
-0.0000
+0.0005
Thats the tolerance I follow. I hone them if there to tight.
Any one else use this tol?
